- Joined
- Mar 13, 2020
- Messages
- 2,186
Hi Guys, I am need some help.@craighazan,
I believe you need the latest update of the beta version of Airportitlwm for Sonoma.
As for the BT am not so sure since it seems you already have the updated IntelBTPatcher.
Hi Middleman,Hi @Steve901,
Try changing the Max Kernel to 23.99.99, disable NVMeFix.kext and set Misc > Security > Secure Boot to disabled.
I tried to use Min. *.Kext to avoid the possible conflict.Hi Middleman,
Thank you for reply, What you mentioned have been done, still not working, the same.
Okay. I saw you disabled USBPorts.kext. Why did you do that? That’s an essential kext. Btw you should also disable AppleCPUPmCfgLock & AppleXCPMCfgLock. They’re not required afaik.
I just thought USB have been mapped in ACPI, I already change it into Enable.
And disable AppleCPUPmcfgLock & AppleXCPMCfgLock.
It end up with a rebooting loop.
I even could not have the chance to recognize the failure code.
After many trials and errors my M5A(FX-6300) can boot Sonoma with Clover 5151 now ![pre-release] macOS Sonoma
www.insanelymac.com
The key issue is related to my GPU RX-560 which need RadeonDeInit to avoid blank screen before login desktop and also fix previous unable to wakeup from sleep issue at Ventura/Sonoma now !
Can anyone help me how to convert RadeonInit function to OpenCore ?
But in my hackintosh it keeps on blank screen which means no working of WhateverGreen.There's no need. According to the Dortania guide this function is now handled by Whatevergreen automatically.
Well in that case the RadeonDeinit SSDT is there should you need it, under the Dortania Clover to Opencore conversion guide.But in my hackintosh it keeps on blank screen which means no working of WhateverGreen.
Only booted by Clover 5151 can fix this issue now.
Unfortunately that SSDT.aml did not fix RX-560's blank screen issue at all.Well in that case the RadeonDeinit SSDT is there should you need it, under the Dortania Clover to Opencore conversion guide.
Thanks for your advice.Did you edit the SSDT-Radeon-Deinit.dsl table and then compile the table to create a SSDT-Radeon-Deinit.aml table that matches the ACPI address for your RX560? As using the SSDT in its default format won't necessarily match and work with your system.
This is the default ACPI address/path used in the SSDT.
Does this match with your GPU's ACPI address/path? Check in IORegistryExplorer or on the Hackintool > PCIe devices tab to see which ACPI address/path your GPU uses.
