macOS Sonoma on AMD
11
1,406
212
33
Scotland
amd-osx.com
Ryzen 5 5600X
With only changing the MaxVersion on the kernel patches and updating Lilu macOS Sonoma works just fine :D
Edit: I don't recommend updating your current system with Sonoma. If you want to test it use a different drive/partition.
update is out...
Just letting you guys know IntelBTPatcher has been fixed with regards to crashing (with Sonoma).
What am I missing?. WiFi works great in Ventura but not in Sonoma, unsurprisingly!. But BlueTooth is my priority here, I can switch it on in Ventura and Sonoma but it switches off again after 30 seconds. Screenshot 2023-08-04 at 9.24.21 AM.png
@craighazan,
I believe you need the latest update of the beta version of Airportitlwm for Sonoma.
As for the BT am not so sure since it seems you already have the updated IntelBTPatcher.
Reactions: craighazan
@craighazan,
Hi Guys, I am need some help.
I am trying to install sonoma in another separate SSD. it get blocked during booting;
What I have done:
1. Update 1.66 Lilu
2. Set Max Kernel as 23.29.29 (This was wrong type, in EFI, it is 23.99.99)
3. Delete old CPU paths and update with new version, and change the setting to 6 cores.
4. Use the EFI which working well for Ventura.
5. NVMeFix.kext have been disabled.
6. EFI attached.
What else I have missed ?
1691207214936-png.11580
Hi @Steve901,
Try changing the Max Kernel to 23.99.99, disable NVMeFix.kext and set Misc > Security > Secure Boot to disabled.
Hi @Steve901,
Hi Middleman,
Thank you for reply, What you mentioned have been done, still not working, the same.
Okay. I saw you disabled USBPorts.kext. Why did you do that? That’s an essential kext. Btw you should also disable AppleCPUPmCfgLock & AppleXCPMCfgLock. They’re not required afaik.
I just thought USB have been mapped in ACPI, I already change it into Enable.
And disable AppleCPUPmcfgLock & AppleXCPMCfgLock.
It end up with a rebooting loop.
I even could not have the chance to recognize the failure code. :ROFLMAO:
Reactions: Middleman
I successfully managed to install Sonoma on my PC. (Main issue was the Max Kernel in CPU path )
But with two Mac system, you should be very careful, access the file of different OS might cause trouble.
And Ventura seems smoother and more stable than Sonoma.
Avoiding conflicts, I have deleted the Sonoma SSD.
After many trials and errors my M5A(FX-6300) can boot Sonoma with Clover 5151 now !
The key issue is related to my GPU RX-560 which need RadeonDeInit to avoid blank screen before login desktop and also fix previous unable to wakeup from sleep issue at Ventura/Sonoma now !
Can anyone help me how to convert RadeonInit function to OpenCore ?
    config.plist
There's no need. According to the Dortania guide this function is now handled by Whatevergreen automatically.
But in my hackintosh it keeps on blank screen which means no working of WhateverGreen.
Only booted by Clover 5151 can fix this issue now.
Well in that case the RadeonDeinit SSDT is there should you need it, under the Dortania Clover to Opencore conversion guide.
Unfortunately that SSDT.aml did not fix RX-560's blank screen issue at all.
So up to now I can boot by Clover 5151/5154 only without this blank screen issue.
Did you edit the SSDT-Radeon-Deinit.dsl table and then compile the table to create a SSDT-Radeon-Deinit.aml table that matches the ACPI address for your RX560? As using the SSDT in its default format won't necessarily match and work with your system.
This is the default ACPI address/path used in the SSDT.
Does this match with your GPU's ACPI address/path? Check in IORegistryExplorer or on the Hackintool > PCIe devices tab to see which ACPI address/path your GPU uses.
Reactions: jsl2020
Thanks for your advice.
I have modified its ACPI address/path to mines according to Hacintool/IORegistryExplorer, but still got blank screen issue if booted by OpenCore 0.9.4.
No such an issue if booted by Clover 5151/5154 which bothered me up to now because there's two bugs in my legacy boot Clover:
1. Loss of boot-args in NVRAM after login desktop. I must enter Terminal to fix it by sudo nvram boot-args="xxxxxxxxxxxx".
2. Unable to update my hackintosh at BigSur/Monterey/Ventura/Sonoma in which it always got reboot-loop during update.
That's why I'm asking for help to fix this quite unusual blank screen issue of RX560 in M5A(FX-6300) if booted by OpenCore.
I need a second pair of eyes to check things over.
Thought upgrading would be a cinch, but I keep running onto the same issue. Apple logo appears, the progress bar rockets to 10% in a fraction of a second and reboots.
All Kexts updated, OC updated, and max kernel versions changed.
I ran into that installer behavior when I booted to Ventura while Sonoma MacOS Installer boot option was available (had to make quick changes to OC config).
The problem went away by having Ventura download the update all over again and try installing again from start.
I see limit cpu cores kernel patch maxkernel is not 23.x.x but I’m guessing it was a new patch from github.
