Sure, I will stick with the EFI from post #50
I need to verify the rename you posted, I copied it without even verifyingI need to verify the rename you posted, I copied it without even verifying 🙈
What happens if we leave TableSignature empty? Does this mean the patch was not applied?
Probably yes, we'll see when last efi test 🤷
In your previous EFI, TableSignature is correct:
But it is empty in this EFI:
Reactions: Lorys89
Not working as Casey suspected. Odd thing is that I opened the confi.plist the Table Signature is already there (as DSDT), not empty ( #82 EFI).
By the way, when I open the config.plist there is a warning (but it's present in the working EFI #50 as well):
OCS: No schema for ResizeUsePciRbIo at 12 index, context <Quirks>!
Serialisation returns 1 error!
As main efi it uses #50, but it's strange it doesn't start the efi with the rename of the name prw to xprw 🤪
In the next few hours I will check better
Reactions: jubarim
So perhaps it is necessary to rename Method _PRW instead of Name _PRW. Hopefully another Gigabyte AM5 user can double-confirm.
We can ignore this warning for now. When OpenCore Configurator is updated for OC 0.9.0 this will disappear.
Reactions: jubarim
Reactions: CaseySJ
Reactions: jubarim and Lorys89
Will try it tomorrow. I have a feeling that ACPI changes have been made that will need some config.plist tweaking…
In the hero nothing has changed and always starts macos, they solved something about ram stability
Reactions: CaseySJ
I am flashing the latest BIOS now. Using EZ Flash causes code 11 on POST code LED and system freezes. This is due to:
  • BIOS -> Advanced -> AMD CBS -> UMC Common Options -> DDR Options -> DDR Memory Features -> Memory Context Restore -> Enabled
After selecting "Load Optimized Defaults", saving the settings, rebooting, and re-entering BIOS Setup, I am able to flash the new BIOS.
I will re-enable that setting shortly.
Update: BIOS 0925 is working well so far. No issues with EFI configuration.
So wrapping up my Gigabyte Aorus Pro AX EFI, do you think it's successful enough to create a post in "Success Stories"?
I can post the current EFI with the credits of everyone that helped me here.
By the way, I will have to pause hacking until a buy a new VGA.
I was also gaming using my RX 6800 XT, bought used:
  • Red Dead Redemption 2 quitting out of nowhere after a few minutes.
  • I could not finish the 3dMark Time Spy once (tried multiple times) - in this case the computer reboots and there is a long and 3 short beeps --> "1 long beep accompanied by 3 short beeps means an AGP error"
So I"m returning it tomorrow, it was probably using in mining...
Please do.
Reactions: jubarim
Please do.
I'll do that later today.
By the way, after I removed the 6800XT, I tried to boot using the integrated graphics of Ryzen 7900X: macos booted fine (of course with no video acceleration).
@jubarim please try form this efi :)
@CaseySJ
I used the gigabyte patched dsdt sent by you, where the _prw method is already renamed to xprw and so it just finds the name _prw and renames it to zprw
do you think it can work?
@CaseySJ
Are you trying to rename both method and name? The DSDT opens in MaciASL if either one of those is renamed.
