Looks like IOPCIFamilly is too old to be downgraded...@ExtremeXT
It has not worked, when putting IOPCI of Big Sur this Ryzen restarts when passing the pre-boot![]()
@PoMpIs
Can you try booting macOS 12.0.0 installer?
Closest one to initial release would be best... I want to see if this problem is on day 0 release.But it is not clear to me even if the problem is because it is AMD and not having AppleVTD? or by Asus bios??
Being honest, is it possible for PCIE to work?
If now I can do installations from Ryzen itself... but does it have to be exactly that version 12.0.0??
What's the earliest one you found?
Does GibMacOS still have early Monterey builds?
No idea...Does GibMacOS still have early Monterey builds?
bash-3.2# sysctl -a | grep tsc
kern.hv.clock.tsc_base: 316326768570
kern.hv.clock.tsc_clock_last: 7795896690645
net.pktsched.netem.heap_size: 2048
net.pktsched.netem.sched_output_ival_ms: 1
net.pktsched.verbose: 0
machdep.tsc.nanotime.tsc_base: 19080030060
machdep.tsc.nanotime.ns_base: 1671591446160
machdep.tsc.nanotime.scale: 908533176
machdep.tsc.nanotime.shift: 0
machdep.tsc.nanotime.generation: 3
machdep.tsc.frequency: 4727364290
machdep.tsc.deep_idle_rebase: 1
machdep.tsc.at_boot: 0
machdep.tsc.rebase_abs_time: 44422586670
machdep.cpu.tsc_ccc.numerator: 0
machdep.cpu.tsc_ccc.denominator: 0
pompis@Pro-de-PoMpIs ~ % sysctl -a | grep tsc
kern.hv.clock.tsc_base: 274921565400
kern.hv.clock.tsc_clock_last: 0
machdep.tsc.nanotime.generation: 2
machdep.tsc.nanotime.ns_base: 0
machdep.tsc.nanotime.scale: 908536090
machdep.tsc.nanotime.tsc_base: 198733383000
machdep.tsc.frequency: 4727349127
machdep.tsc.rebase_abs_time: 42039074575
Seems like very similar issues to the MSI boards tbh. We never could really work out why there was PCI issues with Monterey onwards.
I bought this same motherboard but I intend to return it. (I haven't touched it yet... ) I'm mostly worried that there will be audio issues in macOS. never mind that I bought a 4x16 GB kit of DDR5 ram not realizing that this only has 2 RAM slots.
i'm a total noob with hackintoshing in the OC era but i'm generally very good with "computers" so I learn quick and hope to be helpful in the coming days and weeks.
I think I will go with the X670 Creator Mobo in the end.
also.. i'm going to use a Nactua NHD-15 with 2 fans to cool my 7950x.. do we think this is a bad idea? in the end I can add a 3rd fan to push-push-pull, but I suspect 2 fans will do.
Yes, it's the same thing. I think the only way to have a chance to fix it is serial port debugging... Or maybe a BIOS update from ASUS... Gigabyte for example already released 6 BIOS updates, but ASUS only one which is beta...Seems like very similar issues to the MSI boards tbh. We never could really work out why there was PCI issues with Monterey onwards.
I wouldn't recommend AM5 hackintoshing to a new user... It's still very experimental...I bought this same motherboard but I intend to return it. (I haven't touched it yet... ) I'm mostly worried that there will be audio issues in macOS. never mind that I bought a 4x16 GB kit of DDR5 ram not realizing that this only has 2 RAM slots.
Could you try replacing OpenCore.efi with the DEBUG version of it, setting Target to 67 and sending the log? You can revert back after that.@ExtremeXT No overclock on MacOS... Only on windows..
but I have tried MacOS in all possible ways, and the behavior of PCIe and audio is the same....
I have reset the bios, and I have tried without changing anything in bios, with DOCP, and without DOCP in the memory... I have even physically removed one of the ram modules as @Shaneee recommended at the beginning...I even flashed the pre-beta bios, and it didn't do anything either...and there are only two bios versions for this motherboard... ... nothing makes this work..... I can't think of anything else to do![]()
Maybe AMDRyzenCPUPowerManagement needs a tuning update... What motherboard do you have by the way?Any idea why my GB5 benchmarks and CB23 multithread benchmarks are as expected for 7950x. But single thread Cinebench 23 scores are very low only 1400 or so (2000+ on windows). It seems like the CPU boosts to 5Ghz+ all cores during multithread but on single thread it kinda wonders between 3+Ghz to 5+Ghz.
ASUS x670 StrixE-A, https://rog.asus.com/motherboards/rog-strix/rog-strix-x670e-a-gaming-wifi-model, it's almost the same as StrixE-FMaybe AMDRyzenCPUPowerManagement needs a tuning update... What motherboard do you have by the way?
Does your PCIe work?ASUS x670 StrixE-A, https://rog.asus.com/motherboards/rog-strix/rog-strix-x670e-a-gaming-wifi-model, it's almost the same as StrixE-F
