Fingers crossed it won't require new kernel patches or OC updates.
It is compatible with existing AM5 platforms, and X870(E) is apparently the same silicon as X670/B650, so it looks like BIOS updates could be the main issue.
如有兴趣,请写在那里。
Can you fix my DSDT.aml file. I am using the Asus B650E-F 2412. Thank you.
Ok, I'll do it to you in a while, see you later
Reactions: Ryu
Reactions: Ryu and CaseySJ
Reactions: CaseySJ and Lorys89
If the only error that is preventing DSDT from loading is due to the highlighted error...
... then the missing ACPI path \_SB_.PCI0.GPP7.UP00.DP60.XH00 is conditionally defined by this:
As we can see, there are 3 conditions:
C:
    If (((G002 != 0x03) && ((G000 == One) && (
        G004 != 0x43FA1022))))
We could create an ACPI patch to change any or all of the conditions. Fortunately there are no other references to PCI0.GPP7.UP00.DP60, which means we don't have to worry about a conflicting device tree being created at the same path.
How to create it, and is there a tutorial?
