That's the same motherboard I've been eyeballing, hope the build goes well.
I wanted so much to put that into the new SSUPD Meshroom S, but alas there are right-angle connectors (front panel USB 3 header, one ARGB header, one USB 2 header, two SATA headers) that just won't work with the two extra millimeters of length in the Meshroom S (i.e., the case is just 2mm longer than the board).
My current choice is the Jonsbo D30 mATX case. NewEgg should have a new silver version in a few days.
Reactions: PoMpIs
7950x, x670 Strix E-A in Monterey, boots normally, sleep works, no PCIE from anything other than the main x16 slot(6600XT).
NVME drives causes immediate reboot. Fenvi in PCIE x1 doesn't work. Any idea what the ASUS PCIE bug could be?
Same as on my motherboard...
Disable PCIE ARI in bios helps stability, although no PCIe will work in monterey or in ventura only the GPU... but you can install any MacOS from ryzen itself, without the help of another computer
As mentioned previously, the current X670 firmware for most Asus boards is still in Beta. So perhaps this is an ideal time to report problems to them...
PCIe in Big Sur worked though right?
Update:
  • All of the parts have arrived. PSU, GPU, WiFi/BT will be cannibalized from other systems for the time being.
  • But why the two coolers in the picture?
    • I got nervous about the BeQuiet Pure Loop and decided to get the DeepCool LS520 as well
    • Both are currently unopened
    • If anyone has a recommendation between them, I'm all ears...
It's a busy day at the office so assembly will most likely take place tomorrow or Saturday.
@PoMpIs
Can you run MaciASL, press New > New from ACPI and select DMAR? Then send the file here. I have a new idea to fix PCI.
@PoMpIs
I don't recall seeing DMAR table on Ryzen...but I could be wrong.
Looks like you're right, it doesn't exist...
@PoMpIs
Can you try enabling ProtectMemoryRegions?
Reactions: PoMpIs
@ExtremeXT
Nothing changes... the PCIe still don't work, and if I don't remove the NVMe I can't start Monterey or Ventura, it's panic
Try disabling MmioWhitelist -> Entry 1 (second entry), if it's booting do the same to Entry 3.
Can you get a kernel log from Monterey/Ventura?
Well, it works like this: (I'm going to remove the one that remains because now maybe not having the iGPU is not necessary)
This is in Ventura
This is in Ventura
You should still disable the iGPU.
Try installing Big Sur IOPCIFamily with Hackintool.
I have not explained well...
the IGPU is deactivated... and that is why it now works with fewer patches??
But to boot I can't remove more... it has to be like this:
I'm going to try to install the Kext with hackintool... the installation of monterey and ventura will break again 😆
Don't do it on Ventura, do it on Monterey.
