- Joined
- Aug 7, 2022
- Messages
- 843
Can you try toggling more PCIe settings in the BIOS?****!!, I forgot to activate the kext AppleIntel210 in ventura... ...as soon as I get home I'll try...
and yes, it is stable in ventura with that efi and it goes better than big sur, the system is smoother
but the NVME is necessary to remove it otherwise there is a panic shortly after passing the pre-boot...
the audio via HDMI/DP in ventura works quite well... the ALC4080 is impossible, it is useless in any of the three systems tested (big sur, monterey and ventura)...very bad
