Can you retake BIOS screenshots (with screenshot function of ASUS BIOS) (without AI Tweaker as it should be useless) and upload all of them on imgur? I feel like there might be some interesting ones...
I already have it without the RL and without the GPU, on Monday they come to get it, and then I buy a Raptor lake...
But the bios is exactly the same, with this update nothing has changed, only a new DOCP profile has appeared, which is DOCP-II
If the Audio worked for me, I wouldn't have a problem using it, but if I can't use the audio, it's no use, and I don't want to be pessimistic, but I don't think the audio is easy to solve.
I leave here the latest EFI, with it I can install Big Sur without any problem, and everything works except Audio, and even if you use an external audio card it doesn't work well... HDMI/DP audio works better, but it has cuts.
In monterey you can install and update the system without problem, but I will not be able to use any NVMe in any of the M.2, and the other PCIe ports even if you put any card will not work, neither the i225v network
In Ventura it's the same as in monterey, you can install the system, and it works fine, but you can't use M.2 or any other PCIe other than the GPU.
The 7950x is a very good processor, but the motherboards are very expensive... with what the 7950x cost me plus the motherboard I have enough to buy a 13900k and a z790 and I suppose that I will have much less problems installing MacOS.
