if you want to try it:
GitHub - Lorys89/SMCProcessorAMD: VirtualSMC plugin for AMD processors
VirtualSMC plugin for AMD processors. Contribute to Lorys89/SMCProcessorAMD development by creating an account on GitHub.
ForceAquantiaEthernet
because AQC-107 is not being recognized in Sonoma beta 2:Can you post the Ventura and Sonoma patches side by side? Byte masking might be viable to combine them.** Aquantia Patches Updated for macOS Sonoma **
Sonoma Beta 1 only
@Tormod informed me that our Aquantia patches were not working in macOS Sonoma. The conversation is located here. Although the driver is the same in Sonoma, it has been recompiled, which results in some surrounding bytes being modified. An updated patch set has been posted to the GitHub repo referenced below.
Fortunately we can still use the 2 mask-based patches, one of which had to be modified.
GitHub - CaseySJ/Aquantia-macOS-Patches: Patches to enable AppleEthernetAquantiaAqtion in macOS when AppleVTD is not available
Patches to enable AppleEthernetAquantiaAqtion in macOS when AppleVTD is not available - CaseySJ/Aquantia-macOS-Patchesgithub.com
The device in the image is Broadcom Wi-Fi.UPDATE:
- The new patches may not work in Sonoma Beta 2. I tested them in Beta 1 only. Checking...
- KDK for beta 2 has not yet been posted to Apple's developer downloads. Cannot proceed until it becomes available.
UPDATE 2:
- It seems we may need to update kernel quirk
Byte masking has been applied -- the Set 2 patches in this post work across Monterey, Ventura and Sonoma:Can you post the Ventura and Sonoma patches side by side? Byte masking might be viable to combine them.
Oops!! New screenshot coming soon...The device in the image is Broadcom Wi-Fi.
10 Gbit Ethernet
Ryzen 5950x Asus ROG Crosshair VIII EXTREME X570 The guy who installed Big Sur said, only 2.5 Eth will work onboard. Now I need to establish a dedicated 10gbit ethernet connected to another machine. There is a 10gbit input, but it looks dead, doesn't blink when I plug in the cable. Asus says...forum.amd-osx.com
Awesome! So I was right about
... Unfortunately the Ryzen 7900 XT/XTX do not work in macOS. I was hoping for support to be added in Sonoma, but that is looking unlikely.hello !
the card graphics amd 7900 xt/ xtx is not work or work ?
the mainboard amd am5 ryzen is work matched functions
thank you !
** Intel WiFi with Sonoma **
As others are pointing out, we can indeed use itlwm in combination with HeliPort to use on-board Intel WiFi with Sonoma. At this time there is no Sonoma version of AirportItlwm, hence the need to use just itlwm.
When system starts up, run HeliPort from Applications folder. You should then see a WiFi icon in menu bar. Select your SSID from there.
- Copy itlwm.kext into EFI/OC/Kexts
- Add an entry in config.plist -> Kernel
- Download HeliPort and copy it into Applications folder
- We can keep SIP enabled (csr-active-config 00000000)
- Reboot
On my Asus X670E Gene, the on-board Intel WiFi is just as fast as wired Ethernet!
Voltage work good.
Is it work fine? Could you share the appropriate EFI file with me please.View attachment 10957
Thanks to the great jobs done @CaseySJ and @ExtremeXT (ExtremeXT helped me to adjust some kext patches to break open core masking limits)
Clover boots and all devices are seen (ethernet/wifi/bt/thunderbolt in macOS Ventura) and all the same except WIFI in the first macOS onoma beta
AM5 users will have Audio problem (as we have had in the past before @Shaneee solution)..but maybe some coder could try to solve also this remaining Clover Problem....
Opencore is the best and more updated boot loader , I like to have also Clover booting in my system![]()
so No War please
