** Intel WiFi with Sonoma **
As others are pointing out, we can indeed use
itlwm in combination with
HeliPort to use on-board Intel WiFi with Sonoma. At this time there is no Sonoma version of
AirportItlwm, hence the need to use just
itlwm.
- Copy itlwm.kext into EFI/OC/Kexts
- Add an entry in config.plist -> Kernel
- Download HeliPort and copy it into Applications folder
- We can keep SIP enabled (csr-active-config 00000000)
- Reboot
When system starts up, run
HeliPort from
Applications folder. You should then see a WiFi icon in menu bar. Select your SSID from there.
On my Asus X670E Gene, the on-board Intel WiFi is
just as fast as wired Ethernet!
