OpenCore 0.8.8 Release (January 2nd, 2023) Compiled and Kext updated
Confirmed working for the latest Ventura Release & Beta.
Required BIOS and EFI Setting Links:
Included Kexts
The following commonly used kexts are included but disabled by default.
Enable the kexts as need at your own peril.
NVMe
CPU & GPU temperature + Fan Speeds in iStat Menus (Bottom Fan = Motherboard CPU Fan Header & Blower = Motherboard Chassis Fan header)
As always, Reset NVRAM after making changes to the EFI.
Clean Install - new volume/partition needs to be formatted as APFS. In the past JHFS+ was use, but now the installer fails if the drive was formatted to JHFS+ prior to install.
- BIOS Settings
- EFI Settings (Core Count & GPU)
- Included Kext
- NVRAM Reset
Included Kexts
NVMe
- NVMeFix -> Patches for Apple NVMe storage driver
- AMDRyzenCPUPowerManagement.kext ->Power management features
- AMD Power Gadget App
- V 0.7 Older Version - Kext included in EFI - Shows CPU Temperature in third party apps (custom version of AMDRyzenCPUPowerManagement & SMCAMDProcessor kexts by trulyspinach)
- V 0.7.1 Current Version - Does not show CPU temperature in third party apps, download and update kexts manually
- RadeonSensor.kext ->Read GPU temperature
- RadeonSensor App
- AppleIGB.kext -> Intel 1GB Ethernet
- SmallTreeIntel82576.kext->1GB Intel Ethernet
- Disabled if using AppleIGB
- Enable if using LucyRTL8125Ethernet
- LucyRTL8125Ethernet -> Driver for Realtek RTL8125 2.5GBit Ethernet Controllers
- SMCAMDProcessor.kext -> Publish sensor to VirtualSMC
- SMCRadeonGPU.kext -> Export GPU temperature to VirtualSMC
- SMCSuperIO.kext -> Read fan speeds
