You mean what improvements it has? Mostly stability/cleanliness of the EFI. Are you still having any troubles with the system?@ExtremeXT Works what has the received for improvement? Thanks
Nice! What else is left to fix?@ExtremeXT ..I don't want to say sleep works ..hell yes.....WhooHoogoogle Translate sucks
Sleep Works
Can you send an IOReg dump?@ExtremeXT Wifi works but I can't switch to 5 G and see no other Wlans,... Bluetooth can't pairing with my MX Keyboard
Your Bluetooth port isn't set to Internal in your map, I have changed that in this one, give it a try.@ExtremeXT i have buy this one to install it
What do you mean by the keyboard not working? Is the Wi-Fi fixed? What about Bluetooth?@ExtremeXT @CaseySJ
but the only thing that still doesn't work is with the keyboard... everything feels very good at the moment I'll test and install a few things tonight if I find anything else I'll tell you ..
but first of all I am very satisfied and very grateful to you a really great help and this would not have been possible here I also let you into my system see picture![]()
I just paired my MX Keys to Ryzen 7 7700X as follows:
I had switched to my Fenvi FV-T919 when I posted the previous message...., only the keyboard does not work under Windows, no problem. normally turn on pairing then press connect then enter the number and press enter ... done but the number to betsätigen does not come
@CaseySJ i have buy this one to install it
Good plan!!@ExtremeXT i have buy this one to install it
I think it's a good thing but I don't know about it .... first of all I want to do Hackintosh more strongly again and improve myself there even if that means understanding the new basics better firstYet another option is to try and update the Bluetooth firmware files for AX211 ourselves because the current ones are 13 months old. This may or may not make a difference, however.
