ManuelB
218
82
28
7950X
@ExtremeXT Works what did better in this version Thanks
Reactions: ExtremeXT
@ExtremeXT Works what has the received for improvement? Thanks
You mean what improvements it has? Mostly stability/cleanliness of the EFI. Are you still having any troubles with the system?
@ExtremeXT ..I don't want to say sleep works ..hell yes.....WhooHoo :) google Translate sucks
Sleep Works
Reactions: ManuelB
@ExtremeXT Wifi works but I can't switch to 5 G and see no other Wlans,... Bluetooth can't pairing with my MX Keyboard other device work´s
@ExtremeXT @CaseySJ
but the only thing that still doesn't work is with the keyboard... everything feels very good at the moment I'll test and install a few things tonight if I find anything else I'll tell you ..
but first of all I am very satisfied and very grateful to you a really great help and this would not have been possible here I also let you into my system see picture :)
@ExtremeXT @CaseySJ
What do you mean by the keyboard not working? Is the Wi-Fi fixed? What about Bluetooth?
@ExtremeXT @CaseySJ
I just paired my MX Keys to Ryzen 7 7700X as follows:
  • Keyboard can be paired to 3 devices. Because it is already paired to my MacBook Pro on position 1, I used position 2 for the Ryzen system
  • I had to press and hold F2 for about 3 seconds, then LED starts blinking rapidly
  • In Settings --> Bluetooth, the keyboard appears in Nearby Devices
  • I then followed on-screen instructions and it works well
Full instructions are located here (English):
Optionally you may try Logitech's Options+ software:
@CaseySJ @ExtremeXT Thanks for the instructions I had already read half an hour ago to look for errors ... and on my Macbook it works as described only on Hackintosh not that's the funny thing .... WiFi works AirPods Max and that Catcher from my Marantz receiver, only the keyboard does not work under Windows, no problem. normally turn on pairing then press connect then enter the number and press enter ... done but the number to betsätigen does not come
..., only the keyboard does not work under Windows, no problem. normally turn on pairing then press connect then enter the number and press enter ... done but the number to betsätigen does not come
I had switched to my Fenvi FV-T919 when I posted the previous message.
Now I switched back to Intel WiFi/BT and the same problem happens to me: Logitech MX Keys will not pair/connect with current version of Intel Bluetooth driver.
But we know it works with Fenvi FV-T919. It might be a good idea to consider switching to a Broadcom-based WiFi/BT card. The OpenIntelWireless drivers are much better than they used to be, but they are still not as good as Apple's own drivers.
Another option is to report this problem to the OpenIntelWireless team here:
Yet another option is to try and update the Bluetooth firmware files for AX211 ourselves because the current ones are 13 months old. This may or may not make a difference, however.
@ManuelB Besides Wi-Fi/BT, is there anything else NOT working properly?
I think it's a good thing but I don't know about it .... first of all I want to do Hackintosh more strongly again and improve myself there even if that means understanding the new basics better first :-)
