ManuelB
218
82
28
7950X
@ManuelB have you tried to disconnect ethernet cable in your multiple tests?
Reactions: ExtremeXT
@CaseySJ your CPU has only one CCD?
have in your bios some option related to it?
trx40 has 4 chipset and you can block one or more to start with less core (8/16/24/32)
here is off topic but could be interesting to try
7xxx should have 2 chiplet and a more complex iGPU
to see if audio problem is related to this particular architecture (chiplet , infinity cache )
It does me thinking that if you use some cpu cycle with that app audio is working almost perfectly
Reactions: CaseySJ
@Mariaettosun Network cable is not connected all the time@ExtremeXT ja er hängt hier
every time it hangs you should also add bootlog
have you 4G on in your bios?
have you tried if you have it on to disable and add npci=0x2000 bootarg
I have tested on my system EFI posted by CaseySJ adding only my MMIO
and it boots
could you try to use these two kext (overwrite yours and before backup them)
Just woke up so I’ll look at SysReport soon. Right now my suspicion is on incorrect device EC and a bunch of other ACPI table load failures.
10 tables failed to load.
@mariettosun I think the bios is junk I'm trying to flash it again... no USB is recognized in the Q Flash
@ManuelB I said this some messages ago
playing with MMIO could cause BIOS corruption (it happened in trx40 ASROCK and Gigabyte in the past)
try to flashback with latest bios or use the second bios if you have as a feature
then use latest CaseySJ EFI
Might be an ACPI problem, the other Gigabyte user needed 2 ACPI patches + an SSDT, I'll check their DSDT once I get home.
Yes please flash the latest BIOS using BIOS Flashback if your motherboard supports it. The DSDT is corrupted -- maciASL is unable to open it. The various ACPI table load errors also point to a faulty DSDT.
Update: OpenCore log says you have Gigabyte X670E AORUS Master. It has a Q-Flash Plus button on rear I/O panel, which means it supports BIOS flashback without having to enter BIOS Setup.
What is the model name of your Gigabyte X670(E) motherboard?
It's corrupted from Gigabyte, the other user had the same issue. You need to hex patch _PRW from GPP7 to XPRW and UP00 from GPP7 to UPXX. Then you should be able to decompile it.
to all for info I was able to flash the bios again. This is a Gigabyte X670 Master
You're absolutely right. Those two patches allow DSDT to load!
@ManuelB
All of the changes are in the attached EFI. Please try this EFI folder as-is with no changes.
Update: This EFI also contains SSDT-UPXX-DISABLE.aml from @ExtremeXT
@ManuelB
They also need an SSDT to disable the UPXX device we renamed to.
And I also attached the exact ACPI patches that worked for the other user. They use the Base value which should be a little faster.
Hopefully Gigabyte will fix it in the future.
@ManuelB,
If you refresh/reload this webpage, you will see that I've posted a new EFI folder in Post #94 above. Please use that EFI folder as-is.
@CaseySJ @mariettosun @ExtremeXT I was able to boot it for the first time, it's Russian, but it doesn't matter, I'm trying to install it. Patching isn't my forte, but I think it's very important here. You all have enormous knowledge and without it it doesn't work. You are probably aware that without you there is almost no Hackintosh anymore!!! I would like to thank you from the bottom of my heart that was and is a fantastic support for me and for everyone else here.
Congratulations! Let us know when it's installed, as we need to optimize your MmioWhitelist (as many set to True as possible).
Reactions: fabiosun
I suggest to start with working Schema CaseySJ has found
then, I will suggest to revisit also the quirks used
I would not use SetVirtualMap if he does not have early reboot on boot
Wonderful -- that's more like it!!
By the way, which language do you prefer? I noticed yesterday that language is set to Russian (a remnant of vit9696 :)), but we can change that easily:
We can change it like this:
