ManuelB
218
82
28
7950X
You're not supposed to do that, try setting them like this:
True, True, True, False, True
instead of
True, True, True, True, False
And if it's still not working, try doing it again, but switch the one before the 4th.
if a working MMIO schema was found on CaseySJ motherboard...it would be the same for all x670 motherboard
if you check opencore txt of any manufacturers it is pretty the same (mmio areas) change only the values
The EFI folder I posted yesterday in this thread includes all the MMIO WhiteList entries from my board. It also had the kernel patches configured correctly. Not sure what happened to that folder.
Reactions: fabiosun
I see in this EFiboth patch and bootarg
About MMIO I think they are experimenting
For Casey and the other Gigabyte user it was the last one that had to be devirtualized, but it seems to not be working for them.
in EFI or config posted in public only second MMIO areas is set to skip 1 (on/True)
I think this is good for all
user in this thread mixed bootarg and patch (I do not think is this his problem)
Also in his efi AppleMCEReporterDisabler.kext is disabled
Reactions: ExtremeXT
Wasn't the goal to get as many skip 1s as possible?
Reactions: fabiosun
For the record, my system has been running well with these settings:
as other info, this is ManuelB
MMIO devirt 0xF0000000 (0x8000 pages, 0x800000000000100D)
MMIO devirt 0xFD000000 (0x1E00 pages, 0x800000000000100D)
MMIO devirt 0xFEE00000 (0x1 pages, 0x8000000000000001)
MMIO devirt 0xFEE01000 (0x11FF pages, 0x800000000000100D)
MMIO devirt 0x1080000000 (0x20200 pages, 0x800000000000100D)
and this is CaseySJ:
check the Hex values before pages
@ExtremeXT @CaseySJ I'll attach both to you I have no idea why it doesn't work, I forgot a bootarg or cpu data or or or
Do I have to make a certain bios setting on the new mainboards that wasn't needed before
First of all, make sure your BIOS is the latest version.
Remove SSDT-IGPU-DISABLE and disable iGPU in BIOS.
Remove AGPMInjector.
You set the second MmioWhitelist entry Comment to all of the lines combined, set it to only MMIO devirt 0xFD000000 (0x1E00 Seiten, 0x800000000000100D).
Update your AMD Vanilla Patches.
Remove pci=0x800000 from boot-args.
Then send the new EFI to double check.
it was already set that way
This EFI folder is not the one we were working with before. Everything has been removed from it. Even the AMD kernel patches are not configured.
It's okay to use this EFI folder, but some things need to be configured first.
