How did it get to the PCI stage with the unconfigured coresThis EFI folder is not the one we were working with before. Everything has been removed from it. Even the AMD kernel patches are not configured.
It's okay to use this EFI folder, but some things need to be configured first.
Okay, try setting the third to False too. If it's still stuck there do the second one then first. If it gets stuck at EXITBS re-enable it.now he hangs here and its a little bit faster
Try with all set to false but the second one set to True.@ExtremeXT I've gone through everything, no chance to boot
It is not mmio problem@mariettosun Any ideas?
