zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
I think the USB controller can be identified, but I don't know why, as long as the USB controller is identified, it will be stuck near the loading PCI, which may be IRQ conflict, and it is possible to enter the system only after continuous restart. This is the IOREg I saved in the Big Sur system before, can you see that all the USB are normal
Would Lenovo Slim 7 Gen 7 AMD (16'') with Radeon 6600S hackintoshable with your EFI configuration file?
No idea, try it.
Does Big Sur work without GenericUSBXHCI?
Can be start without GenericUSBXHCI.But it's hard to get start. once the system is restarted, it needs to be rebooted many times to be successful, Using GenericUSBXHCI.kext is for 100% boot success
I just purchased the Alienware Area 51m R2 with the RX5700m. will try hackintosh that one when I get it.
hey, @ExtremeXT, @Visual, I just got a minisforum hx90g, when I install monterey 12.6, I get a kernel panic message, I tried a few patches made by @Visual, but the kernel panic message will Recurrence; if it is convenient, can you provide directions or ideas to solve the problem; thank you very much
You should make a new thread for this, ping me in the OP and attach your EFI, a hardware report in HTML format from HWiNFO64 and a dump of your ACPI tables (use DEBUG OpenCore and enable SysReport in the plist, then try booting macOS and zip the created SysReport folder on the ESP.)
Also aren't you the person who made the original "OC Little" in Chinese? 😅
Reactions: Middleman
Yes @ExtremeXT, because my English is very bad, I rarely visit English-based communities, and now I reply to your information using google translate. I try to open a new topic, attach these information, and then ping you
Reactions: ExtremeXT
I have seen that computers with the same USB controller 1022:1639 can start and recognize USB without any obstacles. I have checked many websites, and the problems all point to EC,RTC and HPET. However, I have checked many times, compared with other DSDT, and tried to modify but failed
Have you tried to just add SSDT-HPET and separated the SSDT-EC-USBX into only SSDT-EC and SSDT-USBX?
If you are skeptical check out the latest EFI I uploaded for @daliansky on his HX90g and see if that arrangement works for you.
:ROFLMAO: I tried to unlock the advanced options in BIOS, thought maybe something about "XHCI Handoff" would help......
Unfortunately, only some options about enable/disable specific usb ports can be found, and disable them didn't help...... (And what's worst is that after I disable "Above 4G MMIO", it won't boot now, even can't boot into BIOS XD...... Have to change the motherboard again I think)
Now the only difference we can see is the port name defined in DSDT...... Those working usb controllers on HP and HX90G seems to be PTRx, and on Levono are called HSPx/SSPx...... Is there any effects on these names?
Yeah, my own laptop for example works with the same controller...
Ports might be an issue, sorry to hear you bricked your laptop though... You should try a CMOS reset.
Unfortunately, you and I have encountered the same problem. I used to set up to turn off Above 4G MMIO. As a result, the black screen of the computer could not be restored, so I had to change the motherboard. I also thought that it might be the confusion of PCI distribution, turning off Above 4G MMIO, and then the Boot-args parameter npci=0x2000. Later, I knew that Above 4G MMIO and Re-Size BAR were together and could not be closed alone. I did not do such a test after changing the motherboard, because I could not restore BIOS. This BIOS chip needs an advanced compiler to write. I don't have that device.
