zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Thanks again for your help,Use USBToolBox will be stuck in USBToolBox: XHC0: waitForMatchingService failed or timed out
Use USBPorts.kext to customize the correct port will be stuck in AppleNVME Assert failed
Using GenericUSBXHCI.kext can enter the system normally even if it is restarted, but cannot be used to start the installation program. It will cause USB failure and can only be installed in a non-USB way, which is why many people cannot install it
Not sure if you know but USBToolbox.kext also requires the use of UTBMap.kext loaded afterwards to work. On top of that for AMD setups you may need a PTXH or XHC rename SSDT for the USB to work. Check out CaseySJ’s guides on Ryzen setups for this.
Reactions: OG Nerd
Yes, the order of using the kext in EFI is correct, and renaming XHC has been tried, but that's not the problem.
Reactions: styde
Have you tried checking the USB ports with Hackintool?
Excellent! I think the problem is the USB controller, because the original EFI by the OP used an outdated kext for generic USB 3.0 (XHCI) support. As a temporary solution, can you try adding that kext? If it boots, I'll make an injector kext that adds native support to Apple's kexts (like XHCI-Unsupported) for Intel. Get the GenericUSBXHCI kext from the OP's EFI.
I took a look at XHCI-unsupported.kext and IOUSBHostFamily.kext yesterday. So if I understand correctly, AppleUSBXHCIPCI is a plugin of IOUSBHostFamily; XHCI-unsupported.kext try to add unsupperted USB controller's device id to AppleUSBXHCIPCI to get native support from Apple's kext.
And I compare the XHCI-unsupported you provided and those can be found on other EFIs, seems that need to choose one key from IOKitPersonalities (each one represents part of the driver). I tested several times, and seems that I can add spoof to AppleAMDUSBXHCIPCI to get boot into 12.6 successfully (without GenericUSBXHCI). This is what I added to XHCI-unsupported.
Now I can get rid of GenericUSBXHCI.kext and use XHCI-unsupported only. However, though I can boot into 12.6, but now all my USB devices won't work (including USB mouse and keyboard), even PS/2 keyboard not working, that's confusing......
I managed to use remote control to take a look at IOReg, seems that AppleAMDUSBXHCIPCI is loaded and show under XHC0 nd XHC1 correctly. Even USBToolBox shows under USB controller too, but no ports show up......
I also tried again adding device-id and compatible properties (0x73a41002 0x73061002 supported by AppleAMDUSBXHCIPCI) under controller in config.plist and disable XHCI-unsupported, but it won't boot without GenericUSBXHCI. Seems that AppleAMDUSBXHCIPCI didn't recognize the controller?
So is using XHCI-unsupported the correct way to drive USB controller (simply just need to test which one to spoof)? Or need to find out how GenericUSBXHCI works and try to fix it?
I also tried again adding device-id and compatible properties (0x73a41002 0x73061002 supported by AppleAMDUSBXHCIPCI) under controller in config.plist, but it won't boot without GenericUSBXHCI. Seems that AppleAMDUSBXHCIPCI didn't recognize the controller?
Do you have the SSDT-EC-USBX.aml or SSDT-UIAC also installed?
SSDT-USBX.aml is installed, but I don't have a SSDT-UIAC.aml......
(For now using EC0 to EC rename patch, disabled SSDT-EC and ECEnabler.kext, just for a test. So far looks normal?)
You shouldn't disable SSDT-EC or SSDT-EC-USBX. That's a vital component for Opencore to run.
I'd also suggest you get a copy of SSDT-UIAC.aml and include it as part of SSDT-USBX.aml.
With these two installed, just try enabling USBInjectAll only and see what ports comes up in the system.
Try that along with your XHCI-unsupported enabled/disabled and see how that affects the USB map.
Then you can run the Terminal scripts to see which ports needs renaming and which don't (as per Dortania USB mapping guide)
and then from there deduce the issues plaguing your current USB map setup.
Reactions: OG Nerd
USBToolBox already does all the necessary renames.
That's not the problem, the problem is that macOS' USB kexts don't load for the laptop's USB controllers as they aren't defined as one (missing the CC part, check image from my desktop)
GenericUSBXHCI is an ancient kext that hasn't been updated in years, I really don't think fixing it is worth it.
What is the Rename EC0 to EC (USB Power) used for? We are already creating a Fake EC with an SSDT, no need to rename ours. Remove that and stay back to our original EC setup.
In the EFI you provided, XhciPortLimit is enabled. That quirk is broken in Big Sur 11.3 and above and usually causes problems such as ours (no USB ports working), I'm pretty sure that that's the problem. You should also remove SSDT-USB-Reset.
SSDT-UIAC and USBInjectAll don't work on AMD chipsets and are totally useless.
I successfully installed it, but it is very difficult to start the installation. It is very likely to be stuck in AppleNVME Assert failed, and I need to restart repeatedly and it will always succeed once. I restart more than 20 times before successful installation,
I have tried to leave only one SN750 hard drive with the same error, GenericUSBXHCI.kext cannot be used to start the installer
Which EFI are you using for 12.6? Can you post it please? I am going to try on mine this coming Monday.
Install 12.6 system, but the installation is difficult, USB problem has not been solved, you need to cancel GenericusBxHCI. kext when installing, select it after the installation
Reactions: OG Nerd
In these days of use found that the system is not stable, a few minutes after successful boot easy to collapse restart
I will ask @Visual to make a patch for that, meanwhile I made a GitHub repo, I can add you to contribuitors if you want.
EDIT: patch in the repo, get the EFI from there
Also, I am trying to fix the backlight in the fix-backlight branch, you can test that if you want.
Reactions: styde
It's nice to have someone willing to help with maintenance
Reactions: ExtremeXT
Reactions: OG Nerd
Still stuck, can't do without GenericusBxHCI. kext
Seems that still need something like XHCI-unsupported.kext (or DummyAppleUSBXHCIPCI.kext, add device-id to one of the CFBundleIdentifier) to tell the kext to recognize the USB controller directly, or it will stall after PCI Configuration End...... (Only once or twice it won't stall after PCI, but still stall at USBToolBox timeout. Haven't tried to add boot-arg "utbwait=xxx" to add custom delay in this situation)
@Shaneee
Hello, after looking on the web I saw that AMD systems used to be problematic in terms of USB in the past, mainly needing kexts like GenericUSBXHCI. (https://www.insanelymac.com/forum/t...zen-without-genericusbxhci-or-injector-kexts/)
The same problem is present on the AMD laptop Lenovo Legion 5 Gen 6, which needs GenericUSBXHCI to boot properly, but even then, only USB periphials work, not USB storage devices. You can see the current progress on the fix-usb branch of my repo: https://github.com/extremegrief1/Lenovo_Legion_5_Hackintosh/tree/fix-usb
We have tried a lot of stuff, like spoofing the USB controller's device ID to B450/B550 (149C), Disabling USB LPM and ASPM, Disabling the RHUBs of each USB controller, modifying XHCI-Unsupported to load our controller into AppleAMDUSBXHCIPCI, etc.
With most of these attempts, it gets stuck around after PCI Configuration End. Do you have any idea on how to fix it?
- ExtremeXT
Reactions: Jo-Toku and styde
Are you sure it's a USB issue? It's a long shot but you could try these, https://forum.amd-osx.com/resources/generic-x570-usb-ssdts.2/
Should allow basic functionality
I'm 100% sure it's an USB issue, because when GenericUSBXHCI is added it boots.
The laptop motherboard is chipset FP6, which I don't think is even a bit close to X570, but since we don't have any more ideas, we'll try that.
As my own laptop has the same exact USB controller, I suspect that some of the ports are causing the issue, but I'm not exactly sure how to disable them, _STA doesn't seem to work... The only notable difference I saw between my laptop's USB controller and the Legion 5's is that mine supports PCIe ASPM, but disabling both ASPM and LPM for the USB controller still didn't work.
- ExtremeXT
