zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
I am using the efi in my post #269 with GenericXHCI.kext enabled as well
Okay you may want try this one first >
I noticed you didn't have a USBX in there, nor PMC.aml. Normally you do need to use SSDT-EC-USBX plus the XHC SSDTs together because it handles the power.
USBInjectall is just the connections map. For laptops SSDT-PMC is required. I've also added the SBUS-MCHC for the Serial Bus which handles the sound chip and other functions.
Also the placement of your USBMap is wrong. Everything must come after Lilu/AppleALC & VirtualSMC and it should be near the middle-bottom.
Technically Whatevergreen should also be there. I haven't added it in but you should.
I have disabled GenericXHCI on this one because it should now work as is.
Reactions: OG Nerd
Ok…. Will try these changes Monday. I tried adding whatevergreen once and when I do, the screen stays black at boot. But, that might be because I don’t have agdpmod=pikera, which is needed for my desktop RX 6600 to work. (This was working without agdpmod=pikera so I never added it.
Reactions: Middleman
HI, can you try installing Monterey? I wonder if Monterey will cause a kernel Panic when installed on other laptops with R7 5800H
No, not if you've set the SSDT-CPUR correctly.
I tried Proxmox and failed miserably. Technically it should have worked but I kept getting a black display. I gave up on it. I could not get Graphics enabled
Try kvm in Ubuntu, that worked on my dell g5 5505(4800h+5600m), and the gpu was successfully passed through. However you will need an external display as well as extra mouse and keyboard
It's very sad, well, at least it works. But alas, you will also have to stay on windows, since it is not comfortable to use the system with VESA, maybe in the future what people will come up with to circumvent this problem:)
@lev12345,
I forgot to mention but I did remember others saying the Vega chipsets supposedly uses DDR ram for the video allocation.
So you could try and add this to the Vega's device properties in config.plist and see if it brings up any better performance or more VRAM:
Key: framebuffer-patch-enable
Value: 01000000
Type: DATA
Key: framebuffer-unifiedmem
Value: 00000080
Type: DATA
So folks,
I just thought of something. I think it would be great if you could also do an IOReg dump of your current 5800H system.
It might be interesting to see how it compares to a desktop based one like mine. Potentially we may find our answer
to the cpus=1 puzzle.
Reactions: OG Nerd
@lev12345,
Value: 01000000
Type: DATA
Value: 00000080
Type: DATA
Hello, nothing has been added, the interface has become a little faster.
So folks,
I hope I sent you what you asked.
Thanks for this and I’ll see what I can find.
But I think I may need @OGNerd’s IOReg dump as well.
Reactions: lev12354
So folks,
Ok, will do this monday
I guess If we wanted a laptop with a 6600M with higher possibility to be hackintoshed we should have gotten this piece of overprice tech 🤣
EDit: Not, that price is silly and with that money may as well buy an M1 max
@Jo-Toku Just want to let you know I just went on HP's site and apparently there's an option to spec the Fury 15 G8 to your own custom specs. So I just went with some minimal options plus the W6600M option ticked. The price turned out to be not so bad, around $2300-2400ish. Definitely not a bad choice if someone is looking for a high end Hackintosh laptop with discrete graphics in my opinion.
Link for the options page if anyone is considering this : https://www.hp.com/us-en/shop/Confi...yId=3074457345620032821&urlLangId=&quantity=1
Wow, Nice! Yikes, ships in September, you must have a lot of patience!
With the EFI you supplied, as is, it hangs at Realtek kext, (photo attached), I am going to try whatevergreen.kext next, but last time I tried it, it would boot to a blank screen.
Here is after whatevergreen.kext is installed and enabled. (Working on the IOReg dump now....)
Ok. Alright then I guess remove the Realek Ethernet kext if you have to, to one that corresponds to your spec.
The realtek is the correct kext, it works on my efi.
Here is my ioreg dump...
I also tried Monterey, but there is only one difference, the system starts up faster, but the graphics also slow down.
What about your USB Ports? Are they working under Monterey?
