Ryzen 9000
Ejh4286
86
Ryzen5950
load default value
then in my case system boots fine
i prefer then to disable
fast boot
Logo
set 1 the speed of something that default is 5
Aura
Serial/com (our proart has one :))
Also i optimize some things in curve shaper following this video (a bit of downvolt in my CPU)
I disable my IGPU from SSDT basic done by @Lorys89 but is it possible also to use separate SSDT (CPUR , USBX and so on)
thats all
PS i use always the latest bios available
Thank you very much for the info. I have no experience with Asus. I will test and try according to your recommendation ... thanks
@fabiosun
Hello :)I still question-my GPU is the RX 6800, which I think is supported native. What do I have to make edits in your efi? In boot-args add agdpmod = pikera? Or rewrite in Device Properites/PcIRoot data my GPU? Thanks for your help
@fabiosun
you need boot arg and whatevergreen kext
i do not remeber if in EFI you use there is spoof in Device Properties for my GPU. If so you have to delete it
Reactions: Pabo
wi fi from broadcom is here now and it is working well :) with OCLP patches
Reactions: Pabo
That's perfect news. Well done! Was it difficult to replace the M2 slot?
I didnt. replace it .this time i have used a PCIE adapter and an internal USB2 port and disabled the internal wifi and BT via bios
Reactions: Pabo
OK-this is better. Please can you publish your complete EFI? Thanks
@x870eProartAsus users :)
Attached my EFI
It has a core count for 9950x and also an initial USB mapping
I will do it better when my broadcom wifi will come
For now all is working as usual
Only for sleep i have an instant wake and for now i will stay with it ;)
@Pabo dont you like this one?
you have only to enable Kext, block and sip when you will insert your wifi :)
and here you can find a detailed guide for WIFI:
Thank you very much for your help and I appreciate it. In your efi, however, there is no BOOT component and I do not know how to do it
Usually i use a boot EFI chooser because i do many test and i have multiple EFI in my EFI partition
this is one you can use with that efi
Reactions: Pabo
Moje OC
@Pabo sorry but this seems a bad mix of my EFI
Are you using OCLP?
if so you have to block new kext in block section
If no
you must not use some kext related to this
also this acpi section is using all i have for testing:
also kext order is a bit messy :)
to be kind :) :)
ACPI section only ssdt basic is active:
Explain a bit if you are using an OLD OS intalled previously or you are doing a new installation
if so no kext below are useful:
Reactions: Pabo
Thanks. I'm doing a brand new installation but I'm a beginner and I already have a panic. I'm very grateful to you if you try to repair me OC
Thanks. I used it but I do a brand new installation and I'm a beginner and I have a panic. So I am very grateful if you try to repair me OC:)
To start dont touch anything and overall do not enabke kext or ssdtπŸ˜‡
Reactions: Pabo
OK It works perfectly only the name Graphic Card is the RX 6950 XT but it does not matter. It will surely be repaired ....
