Ryzen 9000
Ejh4286
86
Ryzen5950
does it work for asus proart x670e?and what’s the function of ssdt-am5 ?
CAnt say if it works also in x670e (MMIO whitlist could be the same or different)
SSDT is usual SSDT used for AM5 platform linked in one ssdt
And x670e ProArt could need of ACPI patching that X870E doesnt need (luckily)
thanks for your answer,my video card is 6800xt, it's metal score 20w+,but opencl score only 3w on geekbench6. What could be the possible reason?
Are you using shaneee or algrey kernel FIX pat patches?
Shaneee one has better result in OpenCL/GL benchmark and games
Use latest in this pictures and your result will be better in opencl/gl (disabel 24 and enable 25 i mean)
Backup your working config before ;)
Reactions: Pabo
additional info
it depends also for OSX version...i use patch 25 with sequoia
23 with oldest system
@ppcook i see you use also a patched DSDT
today there is a better method using ACPI patches in your config ,plist
ask for the proper one for your system/DSDT posting on <AMD - OSX Discord and tagging CorpGhost user/mod
he will help you to build a proper ACPI patches for your system/bios version:
Reactions: ppcook
I boot with your efi(added acpi patchs),then it stuck at applelockdownmode
ppcook66 is me too.....
@ppcook
you should use your working and booting efi
use debug opencore versione and enable sysreport
then post dsdt.aml file you can find it in your EFI partition
from it is possible to build acpi patches
my acpi hero patches could be different from your x670e proart
also my x870e pro art does not need of any acpi patches
By the way, acpi patches dsdt patches are unrelated for GPU lack of performance in Opengl/CL, only the kernel fix pat patchedìs could help for that problem
i m using lgrey kernel FIX pat patches,here's my oc
this attached EFI is like yours but it uses best performances FIX pat patches
if you like try your OpenCL benchmark and see if it improves your score
and here you can find acpi patches for you ASUS x670eProart done by CorpNewt aka CorpGhost :)
I can boot with this ACPI patch,Thanks for your help!
and i got a normal opencl score and cpu single score by changing to shanee‘s kernal pacth。
But i still cannot boot with your efi (added right patch) I got a black screen finnaly hah
I have upgraded to 1.0.3debug,evething work fine,except CPU’s sigle performance,range from high single core score to lower.
Alc1220 is activated by appleallc1.9.3,nice!
Thanks for your help again!@fabiosun
ciao,
i do not know which EFI (of mine ) you are using
My EFI has some spoof for GPU and you do not need of it
Also maybe , my single full ssdt is not working for you
It is possible that we have different MMIOa areas and different USB mapping
ciao,
Do you know how to block devs through ssdt? I want to block my mt7922 and tb4 and other ssd
and 10G ethernet work fine?
