Ryzen 9000
Ejh4286
86
Ryzen5950
I use my Iphone cam sometime in wireless connection with my hack
copy paste from iphone adn hack
this feature work pretty fine
airdrop works
  • Love
Reactions: Galve2000
I attach my EFI for those who have a ASUS ProArt X670E CREATOR WIFI.
I used the OCLP root patch + Broadcom spoof trick to make AirportItlwm.kext work on Sequoia with my AX210.
I still need to make the Thunderbolt/USB4 and the Aquantia card work, I haven't had time to go further for now. You'll have to redo the USBMap accordingly.
What doesn't work: ALC1220 for now, but this is normal under Sequoia (some use VoodooHDA instead).
Will this work for the 7950X including kernel patches?
My X670E Creator / 7950X has been running Monterey rock solid for nearly 2 years and I am reluctant to touch it b/c I am rusty with kerenel patching and I have never tried OCLP whic i will need for my Fenvi card. buy I am kind of hoping to get back into all of this.
Hi, can I use this Fenvi FV-HB1200 for Sequoia with the help of OCLP?
Yes, the Fenvi HB1200 card will work in macOS Sequoia with the OCLP WiFi Root patches.
Reactions: Pabo
for Asus x870e ProArt Creator users
Always it boots without the need to patch acpi :)
Hi boys. Using OCLP I launched BT/WiFi but BT doesn't work. Can you please see where I have a mistake? Thanks
I have Fenvi T919 and I used this guide by Edhawk:
If you want to use a Broadcom WiFi/BT card (Fenvi or other) in Sonoma or Sequoia you need to use OpenCore Legacy Patcher, version 2.0.2. Plus the following kexts and config.plist entries:
Kexts:
  1. AMFIPass.kext v1.4.0+
  2. IOSkywalk.kext v1.1.0 for Sequoia
  3. IO80211FamilyLegacy.kext
    1. AirPortBrcmNIC.kext (IO80211FamilyLegacy.kext plugin)
  4. AirportBrcmFixup.kext v 2.1.9 for Sequoia (optional).
Config.plist entries:
  1. com.apple.iokit.IOSkywalkFamily - Kernel > Block section, must be enabled
  2. Secure Boot Model = Disabled - Misc > Security section
  3. csr-active-config=03080000 - NVRAM > Add section
The Bluetooth should carry on working without any patching.
Reactions: Pabo
@Pabo Probably is not mapped usb you are using and used by your >WIFI/BT card
Reactions: Pabo
Mapping USB does not see the internal USB 2 at all. I have a mistake and I have to look for (BIOS?) I will wait for sequoia 15.2 and do it all new.Thx
You have to map also usb2 you have on motherboard
I did putting there an USB backplate with multiple usb2 ports
If you have problems i could share the usb map i did and to hope is working also for you
Reactions: Pabo
Thanks, it will help me very much if you send it to me. Thanks
if you wanto rto try this is my USB map
It is done for my need
My Broadcom USB part is attaced to internal USB motherboard
i have also an USB2 back plate connected to one of my USB2 motherboard internal connector (and there i have my logitech USB receiver
as you can see here
It is not perfect for now..but it satisfies my needs ;)
Reactions: Pabo
as you can see here
Perfect-FUNT OK !! Thank you very much for your help :cool:
Grazie bene
@leesurone this are patches done by CorpNewt foryour asus x670e-e
  • Love
Reactions: leesurone
Gold medals is for CorpNewt
He is fast and collaborative if people ask for help in this and others task👍
  • Love
It worked like a charm, I've been having issues getting into the discord. I'll try again and see if I can thank him personally.
Reactions: fabiosun
AMD patches do a good job also in 15.3 beta 1
Broadcom wifi and BT work with OCLP patches :)
Reactions: Shaneee and Pabo
