Ryzen 9000
Ejh4286
86
Ryzen5950
Do you know how to block devs through ssdt? I want to block my mt7922 and tb4 and other ssd
and 10G ethernet work fine?
Is turning it off in the bios not possible? Do you need it for another operating system?
i use the same board with:
x7950
xt6600
now sonoma 14.0: no wifi,no bt, no audio
i wana squoia, can you share EFI?
thx~
you cand find one my EFI in this thread or if you like also in this thread
I use a broadcom WIFI/BT and OCLP legacy patcher to have wifi bt working as i like
Do you have a copy of your config. I have the same system of you. Can I have your copy?
this attached EFI is like yours but it uses best performances FIX pat patches
if you like try your OpenCL benchmark and see if it improves your score
I already tried 4 different efi and with yours i have already made boot screen. There was Disk utility and installation. But it was problem with internet connection and security token. Funny thing it was closest build, even this is for different motherboard, but good cpu. Can you help figure out if i post logs and config? Or its possible do just B650e-f + 9700x on 3th port nvme? Thanks.
I am using Asus Strix B850-A and Ryzen 9950X, what .aml s should I use. Now I just use B650E-F.aml, but every boot it will crash when loading apfs, and boot twice, it can success.
