Guys
Big Sur:
All works
true
Not sure if that's good or bad honestly, can you try running it without SSDT-I225V? Curious if we even need it at all. Also, attach your EFI. Is sleep working?
@PoMpIs
Mmmmm... can you try MacOS Monterey 12.2.1 or is that impossible to install now
ok,,, I try and report (y)
GB5:
Can you send the EFI?
Here is the EFI
Now with a network it's nice to use it... before it was torture you walk with the USB from one computer to another
R23:
PS:
I'm trying youtube... the integrated audio is totally unusable... you can hear it but you can hardly understand what they say...
By HDMI/DP it has noise with the system sounds, then the audio on youtube or video is good
Here is the EFI
R23:
PS:
Bluetooth working and everything?
big sur has the same problem as monterey to install, it stays with a gray background and the installation wizard never appears... but the mouse continues to work perfectly
To fix the gray screen problem with the macOS installer, please try this:
I have it disconnected I do not need it but it works.
If you have the USB map right, this FENVI works OOTB
I have a question....
Do these Ryzen 7000 have any chance of working in Ventura?
The bad thing is the audio, I didn't realize it before because I didn't have a network in the ryzen... I think it's worse than the APUs, I've tried what you told me about SpeedKeeper, and it improves a bit, but it's still unusable
Thank you very much.. I'll try it right now (y)
Thanks! Fix added.
@PoMpIs Can you try this one?
Changes:
  • Cleaned out old files
  • Added SSDT-IGPU-DISABLE.aml which should disable the iGPU
  • Disabled PAT patch, TRx40 (19h) works without this so it should work here too since Zen 4 is also 19h, if it gets stuck re-enable patch 16.
  • Merged possible fix from @CaseySJ
Hopefully disabling the iGPU fixes audio, but I'm not sure, we'll see...
Thanks! Fix added.
Changes:
now i go!!
CaseySJ fix works great!!
Thanks! Fix added.
Changes:
Alas, it's still type STRING in config.plist.
Reactions: ExtremeXT
I just found this thread and watching with excitement as the rest of you! I have these items on order:
  • Ryzen 7 7700X
  • Asus Crosshair X670E Gene (mATX board)
  • Be Quiet Pure Loop 2 FX liquid cooler
  • Various other components from existing builds will be cannibalized
  • Ryzen 7 7700X
Hopefully your ASUS motherboard will have better luck... I think we should report this bug to them...
Reactions: CaseySJ
