- Joined
- Aug 7, 2022
- Messages
- 843
Not sure if that's good or bad honestly, can you try running it without SSDT-I225V? Curious if we even need it at all. Also, attach your EFI. Is sleep working?
Can you send the EFI?
Here is the EFI
Now with a network it's nice to use it... before it was torture you walk with the USB from one computer to another
R23:
PS:
I'm trying youtube... the integrated audio is totally unusable... you can hear it but you can hardly understand what they say...
By HDMI/DP it has noise with the system sounds, then the audio on youtube or video is good
Bluetooth working and everything?
Thanks! Fix added.
Thanks! Fix added.
@PoMpIs Can you try this one?
Changes:
Hopefully disabling the iGPU fixes audio, but I'm not sure, we'll see...
- Cleaned out old files
- Added SSDT-IGPU-DISABLE.aml which should disable the iGPU
- Disabled PAT patch, TRx40 (19h) works without this so it should work here too since Zen 4 is also 19h, if it gets stuck re-enable patch 16.
- Merged possible fix from @CaseySJ
Alas, it's still type STRING in config.plist.Thanks! Fix added.
Changes:
Oops, can you fix it and re-send the EFI folder
Certainly. File attached.Oops, can you fix it and re-send the EFI folder
Hopefully your ASUS motherboard will have better luck... I think we should report this bug to them...I just found this thread and watching with excitement as the rest of you! I have these items on order:
- Ryzen 7 7700X
- Asus Crosshair X670E Gene (mATX board)
- Be Quiet Pure Loop 2 FX liquid cooler
- Various other components from existing builds will be cannibalized
OK, enable patch 16.the latest EFI does not work, it gives me a black screen when it should load the desktop
