zxc2689963
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
  • EFI-2023-10-5.zip
Solution
Panic from Monterey 12.6
zljjjjjj
大佬分享一下你的EFI呗,ExtremeXT大佬的我用不了,谢谢
Brother share your EFI, ExtremeXT big guy I can't use it, thank you
Do you have the Intel Wi-Fi + AMD GPU model?
zljjjjjj
HDD: WDSN550(1000 GB, PCI-E 3.0 x4)
Weird that it's crashing, maybe try disabling AirportItlwm.
zxc2689963
This is the EFI I'm using, streamlining some unnecessary Settings and improving stability
  • Only Ventura 13.3+ is supported
  • EFI-2023-4-30.zip
kalkmann
I upgraded to 13.3.1 using your EFI and the boot time is super fast. MacBook Pro SMBIOS and HEVC encode/decode working ok and mostly, Trackpad working! Congratulations on new efforts and discoveries!
I have some questions, which still don't work here:
  • With SSDT-PNLF-CFL.aml present in your ACPI folder, does the brightness control work natively?
  • I saw that you are using a SoftPowerPlay table on the GPU, did this resolve the Sleep on your machine?
Thanks!
Thanks!
HEVC encoding works on MacBookPro SMBIOS? I tried to send you some messages over on Discord too, by the way.
kalkmann
Apparently it's working with this EFI (I just did the simple test with videoproc). It's using MacBookPro15,2 and I haven't made any changes to the config.plist other than the serials.
Sorry about the unread messages... My racing season has started and I barely have time to test/read anything else on the hacks, but they are serving me well in the functions. Thanks for your availability and if I discover something new by chance here, I'll post it on the forum.
Answer when you're able to.
翻斗花园-胡图图
After seeing that you updated EFI, I also re-installed it, and found that the touchpad could work normally. I also bought a network card "AX210" with the same configuration as yours online after I just arrived today and tried it, and it worked normally. However, I seem to find something wrong with the 3.5mm audio interface, and the sound is not normal. I don't know if it is only my computer that has this situation, here is the feedback. It is very impressive that this notebook has been deciphered to this extent by all of you. Thank you for your efforts here.
