Please do β that will help others.After few weeks of testing and daily using without and issues, it's time to creat a success stories? @CaseySJ![]()
Got it. Also uploaded to GitHub tooPlease do β that will help others.
First thought that comes to mind is BIOS setup. In the graphics section thereβs an option to make PCIe graphics the primary output device. Please try that first.
Sounds right. And or the graphics card isn't seated right, the power cables not connected properly, and less likely but possible, the PSU is not rated for the load. I don't see on the motherboard diagram it has diagnostic lights which helps sort out boot errors quickly.First thought that comes to mind in BIOS setup. In the graphics section thereβs an option to make PCIe graphics the primary output device. Please try that first.
Yes, PCIe was the primary and integrated graphics was disabled.First thought that comes to mind in BIOS setup. In the graphics section thereβs an option to make PCIe graphics the primary output device. Please try that first.
6600M6600 or 6650?
It was the resizablebar... I disabled it and it booted fine, thanks!Resizablebar is enable or disable?
To enable Resizable BAR in BIOS, we need to set ResizeAppleGpuBars to 0:
<key>DeviceProperties</key>
<dict>
<key>Add</key>
<dict>
<key>PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)</key>
<dict>
<key>@0,name</key>
<string>ATY,Henbury</string>
<key>@1,name</key>
<key>@2,name</key>
<key>@3,name</key>
<key>device_type</key>
<string>ATY,HenburyParent</string>
</dict>
</dict>
<key>Delete</key>
<dict/>
</dict>
Please keep us posted should the instability return.I forgot to mention I was having another odd issue: the pc rebooted at random times during boot, specially after the screen went off right before the login screen appears - it looked like some concurrency issue.
Anyways, I tried to enable all debugging logs with opencore debug, but it didn't prevent the rebooting (even with all the flags not to reboot with panic, etc).
Searching for instability like that I came across this reddit which sent me this tonymacx86 thread.
Basically I had to add another device property to force a framebuffer for the radeon rx 6600. No more random reboots until now:
<key>@1,name</key>
<key>@2,name</key>
<key>@3,name</key>
I think these might not be strictly necessary:
XML:<key>@1,name</key> <string>ATY,Henbury</string> <key>@2,name</key> <string>ATY,Henbury</string> <key>@3,name</key> <string>ATY,Henbury</string> <key>device_type</key> <string>ATY,HenburyParent</string>
CC: @ExtremeXT
I wonder if thatβs due to MMIO Whitelist. Have you tried disabling all but the 2nd one?I believe you are right, because today I had one reboot in the beginning of the apple boot messages (just after opencore). I can't read anything, super fast reboot.
@jubarim send ioreg log
Bus 002 Device 012: ID 05ac:828d Apple, Inc. Bluetooth USB Host Controller
Bus 002 Device 007: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
Can I ask what the _MACOSX folder is in the zip? I was told to try this EFI and was wondering if I should just move the EFI folder over to my USB or move both.please try this new efi
