What changes did you do that stopped it from working?@ExtremeXT Unfortunately, sleep doesn't work anymore, for whatever reason, just tested again 3 minutes, then woke up with the keyboard, but then a normal boot came up
Nobody booted macOS on an MSI AM5 motherboard yet AFAIK, but there has been a successful report of an ASRock motherboard.I’ve had bad luck with ASRock AM4 boards, but I recall seeing successful build reports from both ASRock and MSI AM5 boards.
That would be an excellent choice. It’s currently my #1 ATX choice.@all ASUS ProArt X670E CREATOR WIFI. am considering whether I should get it to test whether it works better than the gigabyte...???
You have ProvideCustomSlide set to False, which should be set to True on most AMD machines. Your symptoms line up with the slide value being incorrect. Try enabling that.@ExtremeXT
I now have the same phenomenon with my new Install Stick Beta 4. I have to start the installation several times until it runs through. But it works. I have the latest bios, but only use 32 GB of RAM memory. The bios would like to go back to the standard from time to time.
Have you had any difficulties with the B650....which board would you recommend?
Try it with XMP enabled again.@all I've tried it now with 64 GB, too, Sleep went here now, seems like XMP or Provide Custom Slide was responsible for it, everything is fine now...until...now.
