ManuelB
218
82
28
7950X
Reactions: ExtremeXT
@ExtremeXT & @CaseySJ starke Arbeit mit dem Audio opencore 0.8.7 gerade neue EFI getestet !!!
Reactions: CaseySJ
@ManuelB,
Please try the attached EFI folder.
@CaseySJ I can only test it right away the mainboard is bitchy again I'm make a bios update again sorry ..I'm almost thinking about sending it back and complaining, although I haven't liked the quality and the price-performance ratio for the last few years. But I will look to buy another onealthough with the EFI the made do the syteme seems to be faster
@CaseySJ unfortunately no .... which one should I take ... I will test the efi again soon ... but now try to get a clean install on an external one with my new one without any problems ..
@CaseySJ what did you change? at EFI
I made a mistake -- I thought you had Ryzen 9 7950X.
Please try attached config.plist in which I use 8 cores (Ryzen 7 7700X).
@CaseySJ this efi crashes my system
@CaseySJ welche BIOS-Einstellungen haben Sie verwendet?
y@CaseySJ. Das ist die EFI von dir Ich bin zurück zur vorherigen Bios-Version gewechselt und habe weniger Probleme
Try a full power down:
  • Shutdown the computer
  • Flip power switch on PSU to OFF for 10 seconds
  • Switch computer back on
If the problem is still there, then try resetting NVRAM:
  • OpenCore boot menu --> press <space bar>
  • On the right side you will see Reset NVRAM
@CaseySJ I tested it, it then boots Windows, so I don't think the PCI assignment is correct
I've made a number of changes and tested this EFI on my own system.
Please give it a try without making any changes.
If system fails to boot, then try disabling both USBToolBox.kext and UTBMap.kext and try again.
The main problem was bad SSDT-EC.
Reactions: CaseySJ
Your SSDT-SBUS-MCHC is invalid, their device is D036 instead of D033. To find it on AMD systems look for 0x00140000 in the _ADR variable in the DSDT. Also, there is no EC0 device to disable in their DSDT. Also, you used the old MmioWhitelist with only one entry whitelisted.
@ManuelB Give this one a try.
Reactions: ManuelB
@ManuelB,
I recommend changing the file names of these two SSDTs:
  • Change SSDT-EC-USBX.aml to SSDT-EC-USBX-AMD.aml and rename the file in Finder
  • Change SSDT-SBUS-MCHC.aml to SSDT-SBUS-MCHC-AMD.aml and rename the file in Finder
This will allow HackinDROM to upgrade OpenCore for you in the future. If you need help with HackinDROM, just ask.
Screen Shot 2022-11-22 at 7.20.08 AM.pngScreen Shot 2022-11-22 at 7.21.58 AM.png
@ManuelB,
View attachment 8703View attachment 8704
Does it use that to check if it's an AMD system? Can't that be done with the detection of the kernel patches?
