That SSDT tries to disable GPP7.UPXX, but I don’t think BIOS allows it. So we should test sleep/wake with and without that SSDT.@CaseySJ & ExtremeXt or does it have something to do with the ssdt see picture
Please see the link in this post for an example of a NGFF replacement:@CaseySJI can't install the fenvi or is it available as ngff I'll take a look right now I already had it in my old hackintosh. The graphics card would be in the way and would mess up the optics of the computer, the only thing left is to modify the mainboard and still have some WiFi cards there
@ManuelB Please do this but send the latest log as well, the MMIO spaces are likely to have changed.Good to know there’s a new BIOS! Can you please use DEBUG OpenCore.EFI with SysReport enabled and debug target set to 0x67? This will create new SysReport in EFI partition. Please compress and upload that.
It's enough to replace OpenCore.efi with the debug version.@ExtremeXT 6 @CaseySJ I'll try I'm working on a new EFI 0.8.7 but I need a little more time because I want to go through the whole thing slowly now. is there a way to convert a release to DEBUG ..
