This is the same methodology we used in the early days to debug the PCI device problem (10-bit Extended Tag Fields). I want to see what else we can do with it. The ultimate goal is to find a way to bypass AppleVTD in Monterey and Ventura. That would benefit the entire AM5 and AM4 platform.Great post but it should probably be in a Thread of its own, not on page 69. So it is better seen and the others with Aquantia Ethernet issues can also join in testing.
I already tried a custom AppleALC layout, but the microphone still wasn't working.Is this a problem on some AM5 motherboards in particular? But on other AM5 boards (non-USB), the microphone works?
In other words, is this an AppleALC Layout problem, specifically with pin configuration of the inputs and outputs? If it's a pin configuration problem, we can create a new AppleALC Layout. I've documented the procedure here:
Asus Z690 ProArt Creator WiFi (Thunderbolt 4) + i7-12700K + AMD RX 6800 XT
@CaseySJ So more updates and observations. I updated to the latest BIOS, and I did not have the endless loop problem you had. Mine rebooted twice after initial update, each boot continuing to update a different area. After the 2nd reboot it was finished, and it forced me back into the BIOS to...www.tonymacx86.com
You can enable only CPU name patching by adding revpatch=cpuname to NVRAM near revcpuname or boot-args.About restrictevents
Try to put in your config.plist iMacPro 1.1 smbios
Adjust usb kext mapping if you use
You should be able to update with delta update
With MacPro7.1 many users have the same problem @PoMpIs wrote above
For me it is no so big problem because I like graphical interface MacPro 7.1 has in memory panel
With the use of restrictevents kextgraphics of dimm became like if you use iMacPro1.1
And this could be a track to open a bug tracker on axidanthera girhub
thanks @ExtremeXT but this not solve the main problem...Delta update does not work also limiting the kextYou can enable only CPU name patching by adding revpatch=cpuname to NVRAM near revcpuname or boot-args.
Not from my experience, I use RestrictEvents and rev-cpuname in my EFI, I am using iMac19,1 though.Very interesting observation. So RestrictEvents on AMD interferes with incremental macOS updates?
Why? You won't get hardware encoding/decoding or DRM with an iMac SMBIOS and no Intel iGPU.Not from my experience, I use RestrictEvents and rev-cpuname in my EFI, I am using iMac19,1 though.
Sure, but I prefer to watch and listen on my M1 Air attached to Apple Thunderbolt Display. This build is good for creative stuff like the Affinity Apps, eats paths and layers for breakfast!.Why? You won't get hardware encoding/decoding or DRM with an iMac SMBIOS and no Intel iGPU.
What's the reason for using iMac19,1 though?Sure, but I prefer to watch and listen on my M1 Air attached to Apple Thunderbolt Display. This build is good for creative stuff like the Affinity Apps, eats paths and layers for breakfast!.
It was the +15K Metal benchmark in GB5 for my Sapphire RX 580, I started with MacPro7,1 but it wasn't working for me. For my use on this build I'm not concerned with green screens, I'd prefer the better GPU performance.What's the reason for using iMac19,1 though?
I prefer to use MacPro7.1...About restrictevents
We can always disable RestrictEvents, reboot, perform incremental update, then re-enable it.I prefer to use MacPro7.1...
It is not a problem for me that instead of showing 7950x it shows intel xeon W
or to use iMacPro1.1..or better to try to open an issue on the acidanthera bugtrackerWe can always disable RestrictEvents, reboot, perform incremental update, then re-enable it.
@PoMpIs How has your experience with the AM5 system been? Did you find any new issues, incompabilities or stability issues?
Answer for both:
The problem when doing what CaseySJ says, in my system every time I reactivate Kext and reboot for it to take effect, the first boot attempt restarts before reaching the desktop, and the next attempt if everything returns to normal
If I never activate it that never happens..
That Kext to the Ryzen with MacPro7.1 smbios is not doing well at all
but it is a problem only some AMD users have
So it is difficult to find a good way to say
a similar problem have Intel users with a bluetootfix kext
I can't see any open bug tracker on it
