ManuelB
218
82
28
7950X
@CaseySJ & ExtremeXt or does it have something to do with the ssdt see picture
That SSDT tries to disable GPP7.UPXX, but I don’t think BIOS allows it. So we should test sleep/wake with and without that SSDT.
@ManuelB Can you please send your current EFI folder zipped?
@CaseySJI can't install the fenvi or is it available as ngff I'll take a look right now I already had it in my old hackintosh. The graphics card would be in the way and would mess up the optics of the computer, the only thing left is to modify the mainboard and still have some WiFi cards there
Please see the link in this post for an example of a NGFF replacement:
By the way, my Asus X670E has no problem with sleep and wake with on-board Intel WiFi/BT module. This was tested in Ventura.
@CaseySJ
Yes, I have no idea why it isn't running here. I'm not as deep into the topic as you are either... but it was always enough for a well-functioning Hackintosh... but times are changing, and when you've been out of it for 2 years the topic makes you feel like a virgin :) I just saw opencore 0.8.7 is there could you help me to get a clean stick ready that I can also install in German.
I also had a video from technoli (YouTube) that was quite good, but not quite enough.... Zen 4 patches, no problem, I can also use the ssdt that was available a few days ago...but I still have a few questions.
I start setting it up the way I think and you look over?
Sure, I can look over the changes you make to EFI. I would also suggest disconnecting Lian Li device from USB port to see if sleep/wake works. Also disable “Wake for Network Access” from “Settings —> Network”.
    EFI.zip
@CaseySJ & ExtremeXT. I rebuilt the EFI that we created with which I was able to boot for the first time and had installed it in Russian...I can also install German with it, that works well....however, I supposedly couldn't log in with my Apple ID Wrong data...then the computer just went out 2-3....and I had to in the last. Installation step, pull the network cable and he bitched around again. Could you please take a look at the EFi again... I would like to have a reasonable EFI
@Casey & ExtremeXT
I have a question about understanding what opencore is concerned ... all the changes that you have all achieved here, such as. the TSC/FSB for audio in the opencore 0.8.7 added. I have to adjust anything in the opencore? I'm trying to read up on OC now...
and Gigabyte has released a new bios which I couldn't load all the time, I was able to install it today...how can I now determine whether it helped? Should I switch off the ssdt's and see if the boot is successful?
Please excuse all the questions I'm just trying to bring myself up to date
Reactions: ExtremeXT
Good to know there’s a new BIOS! Can you please use DEBUG OpenCore.EFI with SysReport enabled and debug target set to 0x67? This will create new SysReport in EFI partition. Please compress and upload that.
@ManuelB Please do this but send the latest log as well, the MMIO spaces are likely to have changed.
Reactions: CaseySJ
@ExtremeXT 6 @CaseySJ I'll try I'm working on a new EFI 0.8.7 but I need a little more time because I want to go through the whole thing slowly now. is there a way to convert a release to DEBUG ..
It's enough to replace OpenCore.efi with the debug version.
Reactions: CaseySJ
