ManuelB
218
82
28
7950X
@CaseySJ or is it really correct then I have to check again but then we have it
edit. 2 picture alternative
@CaseySJ I hope that fits now......
Please see some questions about front panel USB ports:
  1. The two USB Type A ports are connected to Controller D?
  2. There should be a USB3 port for the second USB Type A port.
  3. Is the USB Type C port connected to Controller E?
Reactions: ExtremeXT
@CaseySJ Just a moment, I'll check that out ja Controller d hat should be no idea how I get e
@CaseySJthere is the missing USB3 Bildschirm-Foto 2022-11-18 um 18.09.19.png und ja orange ixt Typ C. Sorry
Reactions: CaseySJ
Implementation is done. Double checking now.
Reactions: ManuelB
@CaseySJ Ich brauche die Daten noch
@ManuelB,
Attached are 5 files:
  • 3 SSDTs
    • Copy the files to EFI/OC/ACPI folder
      • SSDT-USB-GA-X670E-AORUS-MASTER-GP17.aml
      • SSDT-USB-GA-X670E-AORUS-MASTER-GP19.aml
      • SSDT-USB-GA-X670E-AORUS-MASTER-GPP7.aml
  • 2 Kexts
    • Copy the files to EFI/OC/Kexts folder
      • USBPorts-XHC2-XHC3-XHC4.kext
      • USBPorts-XHC5-XHC6.kext
After copying the files, we need to add them to config.plist as shown below.
NOTE: The old USB port map must be disabled (USBToolBox.kext and UTBMap.kext).
Finally, please reboot, log in, and post a new IORegistryExplorer file.
Screenshot 2022-11-18 at 11.11.09 AM.pngScreenshot 2022-11-18 at 11.12.19 AM.png
The first 2 SSDTs (XHC2, XHC3, XHC4) were activated.
The 3rd SSDT (XHC5, XHC6) did not take effect.
Please post the following screenshots:
  • config.plist --> OpenCore Configurator --> ACPI
  • config.plist --> OpenCore Configurator --> Kernel
Reactions: ManuelB
I'd not recommend OCC for inexperienced people, it somehow bricked my config.plist 2 times before I decided to stop using it.
No app is perfect and I know there's a whole political movement around avoiding configurators, but I do not subscribe to that political party! ;)
@XtremeXT should I make OC Snapshot
It seems the 3rd SSDT may have been rejected by macOS. Can you run this in Terminal:
Bash:
log show --last boot | head -1500 > ~/Documents/bootlog.txt
This will create a file in Documents called bootlog.txt. Please post that file. (No reboot needed.)
Please
