Perfect.@CaseySJ erledigt.
Perfect. Just to double-check…is this a USB 3.x device?[BENUTZER=828] @CaseySJ[/BENUTZER] ist das richtig? Wenn das der Fall ist, gehe ich jeden durch und notiere es, dann schicke ich ein Bild von allem
Good. The port name is PRT1 and it is a hub. That means probably both of the black ports will connect to PRT1. So we can write PRT1 for both of them.again for understanding
Very good!@CaseySJ Das muss man ein paar Mal machen...
I'm not sure I understand the question: "What program do I use to do the labeling?"Noch eine Frage mit welchem Programm machen Sie immer die Beschriftung
@ManuelB@CaseySJ Good morning....I checked everything again yesterday and couldn't think clearly anymoreI have now only used USB2 in USB 2 and only 3 in USB 3 and in 3.2. = USB 3.1 because there was no one else there, I experimented a bit with the Keynote program .... but I think it looks much better and you can understand it better then, I'm curious to see how it goes
That looks really good!!@CaseySJ it is in NZXT H7 Elite
