Please try this: 64 65 3A 30 (this is de:0)@CaseySJ German Please
Or you can set it to blank and it'll ask you to choose the language.Please try this: 64 65 3A 30 (this is de:0)
Alternative: 64 65 2D 44 45 3A 30 (this is de-DE:0)
It's also okay to keep that field empty, but Type must be DATA.
It's based on the file below, but I've not tested it:
OpenCorePkg/Utilities/AppleKeyboardLayouts/AppleKeyboardLayouts.txt at master · acidanthera/OpenCorePkg
OpenCore bootloader. Contribute to acidanthera/OpenCorePkg development by creating an account on GitHub.github.com
The i225-V Ethernet port will crash the computer in Ventura when a cable is connected. At this time we don't have a solution so it's best to use:Also die EFI Stammt von @CaseySJ aber gebootet hat es schlussendlich mit den 2 PatchesPRW from GPP7 to XPRW and UP00 from GPP7 to UPXX.
Warum auch immer es geht nur Russisch hatte beide nr.Probiert und nichts eingetragen trotzdem Russisch und mit Netzwerkkabel StĂ¼rzt der Rechner ab
What Wi-Fi card do you have?What can we do to make BT and WiFi work
You need:Intel wifi 6E AX210
ALC1220-VB is normal audio, not USB.about audio:
@ManuelB motherboard has:
so it is the same USB audio I have
- Realtek® ALC1220-VB CODEC
* The back panel line out jack supports DSD audio.- Support for DTS:X® Ultra
- High Definition Audio
- 2/4/5.1/7.1-channel output
* You can change the functionality of an audio jack using the audio software. To configure
7.1-channel audio, access the audio software for audio settings.- Support for S/PDIF Out
no need of applealc kext
and his IOREG should be pretty similar to this:
View attachment 8367View attachment 8368
left is my audio right Gigabyte x670 (Internal audio)
For audio you need to get AppleALC and try setting layouts.
