ManuelB
218
82
28
7950X
@ManuelB
Attached config.plist uses the ACPI patches from @ExtremeXT instead of the ones I created. Because the credit for these patches belongs to someone else, I think it's best to use their patches directly.
The attached config.plist can be used as-is.
Reactions: ExtremeXT
@ManuelB declare which EFI you have used to boot
and if you have added the acpi SSDT sent by ExtremeXT
otherwise config.plist could fail
Reactions: ManuelB
Please try this: 64 65 3A 30 (this is de:0)
Alternative: 64 65 2D 44 45 3A 30 (this is de-DE:0)
It's also okay to keep that field empty, but Type must be DATA.
It's based on the file below, but I've not tested it:
Or you can set it to blank and it'll ask you to choose the language.
Also die EFI Stammt von @CaseySJ aber gebootet hat es schlussendlich mit den 2 PatchesPRW from GPP7 to XPRW and UP00 from GPP7 to UPXX.
Warum auch immer es geht nur Russisch hatte beide nr.Probiert und nichts eingetragen trotzdem Russisch und mit Netzwerkkabel Stürzt der Rechner ab
The i225-V Ethernet port will crash the computer in Ventura when a cable is connected. At this time we don't have a solution so it's best to use:
  • WiFi
  • USB-to-2.5GbE Ethernet adapter such as this one:
I'm just doing the installation again, have now omitted the text and can now choose. (Language)
What can we do to make BT and WiFi work
Intel wifi 6E AX210
about audio:
@ManuelB motherboard has:
  1. Realtek® ALC1220-VB CODEC
    * The back panel line out jack supports DSD audio.
  2. Support for DTS:X® Ultra
  3. High Definition Audio
  4. 2/4/5.1/7.1-channel output
    * You can change the functionality of an audio jack using the audio software. To configure
    7.1-channel audio, access the audio software for audio settings.
  5. Support for S/PDIF Out
so it is the same USB audio I have
no need of applealc kext
and his IOREG should be pretty similar to this:
left is my audio right Gigabyte x670 (Internal audio)
post your ioreg or try to boot your system without audio jack connection (disconnected from board or case) and see if you see
Post also this page if you like
Intel wifi 6E AX210
You need:
  • AirportItlwm
  • IntelBluetoothFirmware
  • IntelBTPatcher
  • BlueToolFixup
  • USBToolBox
  • UTBMap (map with USBToolBox from Windows)
about audio:
View attachment 8367View attachment 8368
ALC1220-VB is normal audio, not USB.
Reactions: fabiosun
  • Mac Pro von Manuel.zip
Reactions: fabiosun
my error to read another user ioreg
sorry!
I had just tried version 2.1 Monterey of AirportItlwm and my system crashed.. do I have to use a different version or does it only work in conjunction with the entire BT kexten
