well no luck...
with WEG and agdpmod=pikera have a black screen does not load the desktop
and without WEG or agdmod it stays here
Try this one, I reverted to old MmioWhitelist and added AirportBrcmFixup to try to fix Fenvi card.
Kernel panic :eek:
and I see in the vebose an RTC error (lilu)
Kernel panic :eek:
OK, delete AirportBrcmFixup, don't think it's going to work, looks like this board has the PCI-E issues like MSI 500 series ones. Only the GPU slot will work unless someone finds a way to fix it (maybe serial debugging?), so for now remove the card, hopefully the I225 will work now at least...
If I already did, disable the Wi-Fi kext...
but i225 is not working... PCIe should not work either
Reactions: ExtremeXT
Can you send the dmesg log?
Reactions: PoMpIs
@PoMpIs Can you try putting your GPU in the second PCI-E slot? That will tell us if it's the same problem as MSI boards. Can you also dump kernel log? dmesg isn't enough.
- ExtremeXT
- ExtremeXT
I can't :ROFLMAO:, the board only has 1 full pcie x16 5.0 port
h525
Looks like according to the above address the settings should be this:
and the PCIRoot path is this -
PciRoot(0x0)/Pci(0x2,0x1)/Pci(0x0,0x0)/Pci(0x8,0x0)/Pci(0x0,0x0)/Pci(0x5,0x0)/Pci(0x0,0x0)
I am using F2158680 because that should be the one to use. F315 is for a secondary LAN port only.
I also tried that config, it didn't work
That's a typo, right? Should be device-id for the first one instead of device-type. Also, why F2158680? It should be F2150000
Not typo error. Because that’s the device values I used to set mine for I-225V LAN under Monterey (without extra drivers). Some earlier versions of macOS pre 12 could get away using F2150000 or even F3150000 but not with the setups needed now.
@PoMpIs Can you try booting Big Sur? AFAIK it doesn't have the PCI lane problem.
