Even when DisableIOMapper is Disabled? Try agdpmod=ignore maybe...
Uufff!!! clear cmos has done the magic...it was making me nervous
I am going to change firmware
Good luck, hopefully it won't fully brick it...Uufff!!! clear cmos has done the magic...it was making me nervous
I am going to change firmware![]()
Did you try that SSDT? Can you send the dmesg log?I already flashed it a while ago, but it still doesn't work
I've tried many configurations and nothing works...
any more ideas?
Have you tried enabling AppleI2xx.kext?I already flashed it a while ago, but it still doesn't work
any more ideas?View attachment 7519
According to that image, the revision ID is incorrect and the SSDT should fix it.I don't think any PCIe is working... only the GPU one... is there a problem with MacOS with the remaining PCIe ports x1 and x4 that connect to the x670e chipset
I'm going to add the ssdt from another computer and look at it please, I don't know if it will be ok
SSDT looks fine, try it.I don't think any PCIe is working... only the GPU one... is there a problem with MacOS with the remaining PCIe ports x1 and x4 that connect to the x670e chipset
I don't know about the PCIe problem, maybe a firmware update will fix it... (or perhaps a BIOS setting?)
Does the Fenvi work in Windows? Did anything change in the last image you sent with the SSDT?NO, that SSDT I already tried it several times and it has no effect .. the network is not loaded
I have been trying the PCIe and in none of them the FENVI works... and that card is native, in the other hackintosh you don't have to do anything, just put it in the PCIe and it works
EDIT: SSDT is wrong, I will send a new one.
My bad... I overwrote another device... sorry, I am not too good in ACPI... this one should work.I get an acpi error in verbose mode and it seems that the ssdt does nothing
View attachment 7523View attachment 7524View attachment 7525View attachment 7526
Here goes the efi!!
Try this one, list of changes:Here goes the efi!!
- Removed USBToolBox and UTBMap as your made an USBMap
- (hopefully) Fixed SSDT-I225V.aml
- Cleaned out MmioWhitelist (hopefully fixed PCI-E issue with Fenvi card, credits @Pavo)
- ExtremeXT
Yeah I enabled WEG, try disabling itblack screen when it should load the desktop, the GPU does not stop the fans, when it enters the desktop well the gpu enters ZeroRPM ..
have you activated WEG?? This computer doesn't like that very much... it usually gives black screens many times if it is used
FENVI I see in the verbose mode the same error as always, I guess not
