Can you install Monterey on the SSD from another computer, and try to boot with the last working EFI?
Downloading!!!!! ;)
It will take a while to download and install, it's a Ryzen 1600AF, it's slow but steady, a rock 🤭
If I see that too much I will go to sleep and tomorrow we continue
Many thanks for the help. 🤗
@PoMpIs,
Yes sure!
If it helps you could add swd_panic=1 into the boot-arg to try and stop the rebooting.
@ExtremeXT @Middleman and all the other guys
I couldn't resist waiting if it works with Monterey..
And I bring good news, IF IT WORKS!!! :p
But the i225v network doesn't work... and the FENVI brcm43xx doesn't work either.
I have taken a lot of screenshots and a copy of IOREG
all images --- >
It works with this EFI... I have changed several things, and I have created a USBMap using Native classes so I don't need USBToolBox, but both methods work very well and my iPhone and iPad charge very quickly, and MacOS still sees the 7950x iGPU
And now I'm going to sleep, tomorrow we continue, today has been a great day
Thank you so much everyone 🤗
Take a well deserved nap!. Great job!.
all images --- >
@PoMpIs,
It's great to hear you got the Monterey up and running! Is it stable? If so I'd love to see how the GB5 compares.
But honestly great work man great work! 👏👏👏
As for the LAN/WiFi that's easy to resolve. Just add e1000=0, remove any existing LAN kexts and add the following into your device properties for Intel I-225V:
BT/WiFi - see if it works as native first if not add Brcm BT drivers including BluetoolFixup.kext, BrcmFirmwareData.kext & BrcmPatchRAM3.kext. Broadcom/Fenvi WiFi requires AirportBrcmFixup.kext.
@PoMpIs,
Fenvi cards should work out of the box without any kexts.... I wonder why it doesn't...
Reactions: PoMpIs
Reactions: PoMpIs
Hello, everyone!!!:)
It does not work!!! It is impossible for me, in this ryzen the i225v does not work, I have the 5900x and an alder lake that also have i225v and it works perfect both in monterey and in Ventura...
And the FENVI is native, I caught it from the Alder Laker to have internet on the ryzen since the i225v doesn't work, but it doesn't work on any PCIe port, in the boot I see it but MacOS doesn't do anything, instead the Bluetooth that the Fenvi has does works
Wow looks like I'm about to place my order now!👏👏👏👏👏👏👏👏
Is it stable so far?
Yes, it is stable, and it does not perform badly, but no network works and I do not have internet 😅,
Correct, and it doesn't work on any of the PCIe.
Connecting the iphone to the USB to share the internet doesn't work either... it connects and everything works, but sharing the iphone connection only works for 30 seconds, then the Ryzen stops having internet
@PoMpIs Does sleep mode work?
I just tried it, it doesn't work, it goes to sleep but when it wakes up it restarts
  • Love
Reactions: Middleman
Can you send a PCIe dump from Hackintool with the NICs enabled/plugged in?
This is what you need???
Try using SSDTTime to make SSDT-Bridge for this path:
PciRoot(0x0)/Pci(0x2,0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)
Reactions: PoMpIs
@PoMpIs Try with this path: PciRoot(0x0)/Pci(0x2,0x1)/Pci(0x0,0x0)/Pci(0x8,0x0)/Pci(0x0,0x0)/Pci(0x4,0x0)/Pci(0x0,0x0)
Also get a hardware report in HTML format from HWiNFO64.
Doesn't it have to do with AppleVTD which is not supported on amd hackintosh
Isn't that only for Aquantia NICs?
@PoMpIs Add this in DeviceProperties to fix Ethernet PciRoot(0x0)\/Pci(0x2,0x1)\/Pci(0x0,0x0)\/Pci(0x8,0x0)\/Pci(0x0,0x0)\/Pci(0x5,0x0)\/Pci(0x0,0x0)
type Dictionary, add a child type Data with name device-id and value F2150000. Make sure e1000=0 is in boot-args. You might need a PCI bridge for that path.
- ExtremeXT
I'm going to get the HWInfo report
- ExtremeXT
I have to try this, I'll tell you in a bit (y)
EDIT: I already tried, it doesn't work
PS: This is the panic that occurs when waking him up from sleep
panic(cpu 14 caller 0xffffff7fa570c9ff): "[3:0:0][PPLIB] Failed Power Play Resume. Shutting back down.
" @AmdRadeonController.cpp:1998
Panicked task 0xffffff99e106c670: 237 threads: pid 0: kernel_task
Backtrace (CPU 14), panicked thread: 0xffffff8b7bca1aa0, Frame : Return Address
0xfffffff58bcd37f0 : 0xffffff801647fdad mach_kernel : _handle_debugger_trap + 0x41d
0xfffffff58bcd3840 : 0xffffff80165e10d6 mach_kernel : _kdp_i386_trap + 0x116
0xfffffff58bcd3880 : 0xffffff80165d0443 mach_kernel : _kernel_trap + 0x4d3
0xfffffff58bcd38d0 : 0xffffff801641fa70 mach_kernel : _return_from_trap + 0xe0
0xfffffff58bcd38f0 : 0xffffff801648017d mach_kernel : _DebuggerTrapWithState + 0xad
0xfffffff58bcd3a10 : 0xffffff801647f936 mach_kernel : _panic_trap_to_debugger + 0x2b6
0xfffffff58bcd3a70 : 0xffffff8016d15093 mach_kernel : _panic + 0x84
0xfffffff58bcd3b60 : 0xffffff7fa570c9ff com.apple.kext.AMDRadeonX6000Framebuffer : __ZN34AMDRadeonX6000_AmdRadeonController10doGPUPanicEPKcz + 0x1b9
0xfffffff58bcd3c70 : 0xffffff7fa56cfea0 com.apple.kext.AMDRadeonX6000Framebuffer : __ZN33AMDRadeonX6000_AmdPowerPlayHelper4wakeEv + 0xc0
0xfffffff58bcd3cb0 : 0xffffff7fa570c238 com.apple.kext.AMDRadeonX6000Framebuffer : __ZN34AMDRadeonX6000_AmdRadeonController4wakeEv + 0xa4
0xfffffff58bcd3ce0 : 0xffffff7fa56ef931 com.apple.kext.AMDRadeonX6000Framebuffer : __ZN35AMDRadeonX6000_AmdRadeonFramebuffer6doWakeEv + 0x5b
0xfffffff58bcd3d00 : 0xffffff7fa56ef86d com.apple.kext.AMDRadeonX6000Framebuffer : __ZN35AMDRadeonX6000_AmdRadeonFramebuffer19setSystemPowerStateENS_15AmdFbPowerStateE + 0x1f
0xfffffff58bcd3d20 : 0xffffff7fa56ef66f com.apple.kext.AMDRadeonX6000Framebuffer : __ZN35AMDRadeonX6000_AmdRadeonFramebuffer18doPowerStateChangeENS_15AmdFbPowerStateE + 0x43
0xfffffff58bcd3d50 : 0xffffff7faf54b21b com.apple.iokit.IOGraphicsFamily : __ZN13IOFramebuffer14checkPowerWorkEj + 0x27d
0xfffffff58bcd3df0 : 0xffffff7faf54af80 com.apple.iokit.IOGraphicsFamily : __ZN14IOFBController14checkPowerWorkEj + 0xa0
0xfffffff58bcd3e20 : 0xffffff7faf55209c com.apple.iokit.IOGraphicsFamily : __ZN13IOFramebuffer10systemWorkEP8OSObjectP22IOInterruptEventSourcei + 0x124
0xfffffff58bcd3ed0 : 0xffffff8016c450e4 mach_kernel : __ZN22IOInterruptEventSource12checkForWorkEv + 0x114
0xfffffff58bcd3f20 : 0xffffff8016c4399e mach_kernel : __ZN10IOWorkLoop15runEventSourcesEv + 0x13e
0xfffffff58bcd3f60 : 0xffffff8016c42fc7 mach_kernel : __ZN10IOWorkLoop10threadMainEv + 0x37
0xfffffff58bcd3fa0 : 0xffffff801641f19e mach_kernel : _call_continuation + 0x2e
         com.apple.iokit.IOGraphicsFamily(597.0)[6971EFFA-C06F-3FC9-AE76-7F2639DEA8B1]@0xffffff7faf53f000->0xffffff7faf56dfff
            dependency: com.apple.iokit.IOPCIFamily(2.9)[31170FF9-33B7-341F-865B-4E0D7872EF82]@0xffffff8019035000->0xffffff8019061fff
         com.apple.kext.AMDRadeonX6000Framebuffer(4.0.8)[510C20B0-0578-3D07-96CD-53013DED9367]@0xffffff7fa56bf000->0xffffff7fa5945fff
            dependency: com.apple.AppleGraphicsDeviceControl(6.5.7)[4279B918-C8C5-3514-924E-3A5AC5C7E44A]@0xffffff7fadd28000->0xffffff7fadd2bfff
            dependency: com.apple.iokit.IOACPIFamily(1.4)[CD3677CB-1370-3425-AB61-064B4F0508E6]@0xffffff8018b8c000->0xffffff8018b8dfff
            dependency: com.apple.iokit.IOGraphicsFamily(597)[6971EFFA-C06F-3FC9-AE76-7F2639DEA8B1]@0xffffff7faf53f000->0xffffff7faf56dfff
Process name corresponding to current thread (0xffffff8b7bca1aa0): kernel_task
Boot args: -v keepsyms=1 debug=0x100 e1000=0 chunklist-security-epoch=0 -chunklist-no-rev2-dev
Mac OS version:
21G115
Kernel version:
Darwin Kernel Version 21.6.0: Mon Aug 22 20:17:10 PDT 2022; root:xnu-8020.140.49~2/RELEASE_X86_64
Kernel UUID: 06A10466-36D7-3A0B-9EE7-A9053A8991A3
KernelCache slide: 0x0000000016200000
KernelCache base:  0xffffff8016400000
Kernel slide:      0x0000000016210000
Kernel text base:  0xffffff8016410000
__HIB  text base: 0xffffff8016300000
System model name: MacPro7,1 (Mac-27AD2F918AE68F61)
System shutdown begun: NO
Panic diags file available: NO (0xe00002bc)
Hibernation exit count: 0
System uptime in nanoseconds: 1002700320520
Last Sleep:           absolute           base_tsc          base_nano
  Uptime  : 0x000000e97598b09c
  Sleep   : 0x000000e7f179cc39 0x00000031a1175a70 0x0000000000000000
  Wake    : 0x000000e86dd4aef6 0x00000005bc701e55 0x000000e86c8193c6
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
  Zone map: 0xffffff8046aaa000 - 0xffffffa046aaa000
  . PGZ   : 0xffffff8046aaa000 - 0xffffff804aaab000
  . VM    : 0xffffff804aaab000 - 0xffffff8516dde000
  . RO    : 0xffffff8516dde000 - 0xffffff86b0444000
  . GEN0  : 0xffffff86b0444000 - 0xffffff8b7c777000
  . GEN1  : 0xffffff8b7c777000 - 0xffffff9048aaa000
  . GEN2  : 0xffffff9048aaa000 - 0xffffff9514ddd000
  . GEN3  : 0xffffff9514ddd000 - 0xffffff99e1110000
  . DATA  : 0xffffff99e1110000 - 0xffffffa046aaa000
  Metadata: 0xffffffa0677bc000 - 0xffffffa0877bc000
  Bitmaps : 0xffffffa0877bc000 - 0xffffffa0937bc000
Reactions: ExtremeXT
Mac OS version:
21G115
Kernel version:
Zone info:
If it's not working can you send another PCIe dump?
The sleep panic is because of the GPU, do you have WhateverGreen?
- ExtremeXT
