Interesting to see if they are actually needed at all. It's entirely possible that the MMIO was actually enough to sort it out. Suppose I should start saving for an upgrade lol
Honestly I believe none of the new patches are needed, but we'll see...
Reactions: Middleman
You mean it restarts after 1 minute? Try adding e1000=0 to boot-args. Could you also send the EFI you're currently using? Do you mind if I post the image (with blurred name) on the AMD OS X Discord server?
- ExtremeXT
Of course, it's a pleasure.. ;)
I enclose in this post the EFI..
I have added e1000=0 but that has broken the boot... I have not been able to re-enter Ventura, or it panics or restarts when it should load the desktop...
It is very unstable... of all the times that it reaches the desktop, it restarts in 40-50 seconds, it does not even have time to take some screenshots from the system itself.
I have put the NVME back to be able to boot into windows and answer that it is easier for me than with the mobile phone
Thanks a lot
Well what can I say @PoMpIs? Congratulations are in order...you did a fine job! :D(y)
Thank you very much, it's very funny 😁
And thank you all for the support
Thanks a lot
Could you try another SSD slot in the motherboard? It has 4 of them.
@PoMpIs
Can you try this EFI? I disabled some patches, hopefully it will make it stabler, send screenshots of the panics and try to boot Monterey instead of Ventura.
- ExtremeXT
Reactions: PoMpIs
It has an Intel 660p 2TB PCIe 3.0 x4
without NVMEFix there is no panic, but it stops here:
I will remove the NVMe from the board to test??? 😁
I also had NVMeFix issues on my AMD build, happened with the past two Ventura Beta updates. I removed it completely.
@PoMpIs
- ExtremeXT
Of course... I'm trying it right now...
I'm already a little nervous :ROFLMAO:
Let's see what happens, I'll report in a few minutes (y)
@ExtremeXT
with this EFI Monterey installer doesn't come up, the screen stays with a gray background... I've waited a few minutes but it doesn't do anything... but the mouse works perfectly
and I always have to take out the nvme otherwise it panics
@ExtremeXT
Might be graphics issue, make sure WhateverGreen is enabled and try to add -radvesa to boot-args.
Reactions: PoMpIs
-wegnoigpu would be better. The dGPU isn't an issue but the iGPU may be causing some issues. If the boot arg doesn't disable it then it's time for a SSDT to disable it.
I already added the devprop for it, I think it should be enough but I'm not sure...
@PoMpIs Could you also try resetting your NVRAM?
Are you sure the PCI Path is correct?
Yeah, they sent a screenshot of it in Windows. I saw that this problem might be fixed with an NVRAM Reset, let's see...
Reactions: PoMpIs and Shaneee
I am going to try..
It takes me a little longer than before because I have to take out the NVMe, and put it back to go to windows :LOL:
Yes of course, I've done it, it doesn't change anything..
What does change in Ventura with the previous EFI, is to disable WEG an agdpmod=pikera and disable i225v in bios to put a FENVI... it allows me to spend more time in Ventura before it restarts:
Captura de pantalla 2022-10-02 a las 22.50.14.pngCaptura de pantalla 2022-10-02 a las 23.03.09.png
I am going to try..
View attachment 7496View attachment 7497
Can you try this EFI too? Does it still panic after some time? Can you send an image of the panic?
if i try now...
I saw the panic log, but I didn't capture it in time before it restarted 🙃
PS: -radvesa did not make any change gray screen .. the mouse works perfectly
Reactions: ExtremeXT
@PoMpIs
Can you try this one? It should work on both Monterey and Ventura.
@Shaneee
Do you think we can merge the last patches for "variant TSC" for 12 and 13 into only one? I think it's possible with Mask and ReplaceMask values, but I don't know how to do it... Maybe you do.
- ExtremeXT
Reactions: PoMpIs
@ExtremeXT
no luck...
it restarts when passing the pre-boot, it does not have time to take a photo
It happens in monterey and ventura
PS: I managed to take a photo of Monterey
Can you install Monterey on the SSD from another computer, and try to boot with the last working EFI?
Reactions: PoMpIs
