zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
@ExtremeXT It may be possible but not easy. Not sure if that would fix the issue though.
Reactions: ExtremeXT
@Shaneee Thanks for your input. I'm pretty sure it would fix it since that's where it panics, but I'm guessing that it's not worth the time.
On another note, this seems like what we need! (Image)
@zty199 Please try this EFI.
@craighazan Do you also have this laptop? If so can you test it?
- ExtremeXT
    EFI.zip
- ExtremeXT
Seems to be the same panic with TSC_sync_margin=0
@zty199 Okay, test this new EFI. It includes a new kernel patch that should fully suppress/remove the panic. Credits to @Visual
- ExtremeXT
I have another PC, but it has been upgraded to Ventura 13.0 beta 5...... I need to downgrade to 12.6 first
Try setting FindMask to nothing (empty) in the TSC kernel patch. I'm not home right now so I cannot send a modified EFI.
Still got OC: Kernel patcher result 17 for kernel - Not Found
BTW, I just install Monterey 12.6 on another PC in an external disk, and I got kernel log from Hackintool. Is this log what you need?
I need the kernel file from /System/Library/Kernels.
EDIT: Don't need it anymore, will send new EFI soon.
- ExtremeXT
@zty199
Here's the new EFI, with a new kernel patch for Monterey 12.6 (old one was for Ventura as that was the only kernel I had on hand).
As before, credits to @Visual.
Good luck.
EDIT: I modified the EFI, if you already downloaded it re-download.
- ExtremeXT
@zty199
Good luck.
- ExtremeXT
:unsure:Now AppleACPIPlatform shows again......
Reactions: zty199
