zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
like in Big Sur. only mice and similar devices work, but the system refuses to read any usb disks
Same here, in big sur, no graphics support, but all CPUS work and USB, but once in Monterey only will boot with CPUS=1 flag and no usb port is working.
The realtek is the correct kext, it works on my efi.
Here is my ioreg dump...
Hi OG Nerd,
So I checked the file and i looks like there's something wrong. I can't seem to open it with IOReg. Could you please export it again but as is without any extensions whatsoever? As I think it is affecting how it is read, thanks.
Reactions: OG Nerd
Okay, so working with @lev12345's IOReg in the meantime I came across this:
The one on the left is lev12345's and the right is from my B550 Vision D. This line is showing the XHC allocation. You'll notice on the right there's a key called driver-child-bundle and it directly refers to Apple's USBCHXCIPCI driver. It's not present in the left one.
More comparisons - here GenericUSBXHCI is doing the allocation. On mine I don't have this since I don't use it.
On lev12345's here under GPP0 nothing has been allocated - but has on my one. However it has somehow gone to GP18 on his.
As to the USB drives not working, I am thinking you may need something like CtlnaAHCIPort.kext added in your kernel.
I am still checking out the files so will let you know if I find anything more about the cpus setting.
I have more findings. Check these out:
Here we are looking at the AppleACPICPU and to check if each core has been recognised by the system. Notice the one key that says IOCPUState shows uninitialized. That doesn't show up on mine.
Then we have AMDRyzenCPUPowerManagement. Here the UserClient is showing on mine but not on yours.
Next there's AppleEFIRuntime. Here everything is the same except on my one is shows IOMatchedAtBoot is True.
Perhaps the issue is related to an SMBIOS setting? I am after all using iMac20,1 on my one and my build has CustomSMBIOSGuid turned off.
One thing I also noticed between the systems is that the AMD Ryzen's use the i386 kernel and Intel based ones have the x86_64 kernel.
Aside from that, I also noticed that under my Device Property tree, I have quite a few devices added.
About the XHCI-unsupported addition, sorry that was an error (from another EFI I mistakenly read).
Reactions: lev12354
Hi OG Nerd,
So, just the bare min. Extensions enabled in config.plastic Or is there a setting in ioreg to dissble Kexts? Also, maybe I am doing the ioreg dump incorrectly, can you please confirm the proper way to do a dump?
Well all you have to do is with your system IOReg open just go to File > Save a Copy As and then save the file onto desktop. It should not have anything on the end ie. TXT nor have any icons attached (should just show a blank page as icon)
I understand correctly that in addition to graphics, the processor itself is also wound up incorrectly?
Yes, from what I've gathered so far. There's something in the new 5800H chip which has somehow been preventing the chips from being utilised properly (compared to the 5800X/5900X chips in say the B550 motherboard setup). The machines so far have to boot with cpus=1 on, but is not needed for 5800X/5900X setups. We are currently working out why that is.
That said, one thing I've been meaning to ask you all is - could you try to boot the system without SSDT-CPUR and SMCAMDProcessor enabled? I ask because another system I looked at the other day DIDN'T require them both and yet somehow initiated a 5950X that was in the system (I think it was a X470 chipset).
Loading stops at given value
Okay in that case try to also disable cpus=1 in the boot-arg as well as RadeonSensor.kext. I think it's dependent on one of the AMD kexts which is why that pops up.
Right. I think I know what the problem is now...
Try this. Put everything back - enable cpus=1, enable SMCAMDProcessor, RadeonSensor and SSDT-CPUR.aml.
But replace your SSDT-CPUR in the ACPI folder with this file here and see if it works (unzip it first). It may
work without cpus=1
work without cpus=1
It loads into the system installer without cpus=1, but does not want to into the previously installed system. Panic photo on system boot without cpus=1.
it is also strange that without the cpus=1 argument, it loads big sur into the installer, but not into the monterey installer
work without cpus=1
with argument cpus=1 loads into the system
Reactions: Middleman
