zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Hi! I have the same problem as @Allen623329. I have a Western Digital disk, so I don't think the problem is in the disk. From our findings, the issue is located in AppleACPICPU, so it ain't disk related
Reactions: Jo-Toku
Some common issues to check:
  1. Are you using any unnecessary Kexts in your setup, CPU power management related?
  2. Have you set Kernel > Emulate > DummyPowerManagement = True
  3. Have you set Kernel > Quirks > ProvideCurrentCPUInfo = True
  4. Have you checked the 3 x AMD Kernel Patches are set correctly for your 8-core CPU?
    • Screenshot 2022-05-31 at 18.38.14.png AMD Kernel Patches for 8-core CPU - 3 x entries highlighted
Reactions: Jo-Toku
Yeah, they are of the correct values
Reactions: Jo-Toku
This EFI should be suitable for all R7 5800H laptops to install Bigsur, of course, you can also try to install Monterey, see if there is a Kernel
i give a shot and it just stop at verbose and the laptop goes off, what should i check in the config? and the opencore doest provide any log file
Reactions: Jo-Toku
To provide the log file you need to use Debug version of Opencore plus debug versions of the Lilu, Whatevergreen, VirtualSMC & AppleALC kexts and enable the AppleDebug box under Misc in the config.plist
Who do you think could write a hack for the TSC_support?
Bad news guys, the 6800hs cpu doesn’t support tsc_adjust either.
I gave up waiting and bought a rog flow x13 2022, it’s 6800hs+3050, I checked in AIDA64 that it also has not support for tsc_adjust8C8C0486-8D5B-40C1-B528-B0082AB586D0.png
By the way, windows11 is really better for touch screen users, and the android subsystem is also great (at least I can use the Apple Music app
  • Sad
Reactions: Jo-Toku
I gave up waiting and bought a rog flow x13 2022, it’s 6800hs+3050, I checked in AIDA64 that it also has not support for tsc_adjustView attachment 6024
So the only way, is having it hacked? I am willing to help donate for somebody that knows how to hack it and make it work
Reactions: OG Nerd
I had heard from two different person that they might have solved it by modding the bios and motherboard themselves, or maybe we are counting on the Opencore team.
Can you get them to elaborate on it a bit more? My legion 5 will be here tomorrow so I will be able to add to testing as well.
Reactions: Jo-Toku
I don't think that the tsc-adjust is the issue... My 5600x also doesn't report it yet works just fine.
  • Wow
Reactions: Jo-Toku and OG Nerd
Do we know what chipset the Legion 5 is using for its mobo?
