zxc2689963
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
  • EFI-2023-10-5.zip
Solution
Panic from Monterey 12.6
zxc2689963
It looks like we have to stop there, tSC_ADJUST is not supported, DSDT has no redundant CPU description,maybe OpenCore will make an analog BIOS module and make the hardware support this function.
I will publish my Monterey installation method and EFI, although there are still many problems. Hopefully, more people will join into improve it, If it succeeds, it could be the most powerful Hackintosh laptop since Apple switched to ARM architecture.
motorbott
Have you tried old version of cputscsync.kext? In that post a guy in the 16th floor mentioned his pc can boot correctly without support for tsc_adjust. Maybe you can contact him for more details.
When you boot with cpus=1 can you share the terminal output of sysctl -a hw machdep.cpu.
zxc2689963
Cputscsync.kext seems to support Intel only. It didn't work
Jo-Toku
Well, bad news.😮‍💨
Is not completely useless. We just need more eyes into this laptops. Again, In peoples minds, Ryzen laptops is no go. Is a matter to get them to consider getting involved to get it properly patched.
I have my Predator Helios 500 with the Ryzen 2700 and Vega 56, but that is desktop masquerade as a laptop. Also the CPU is considerably slower than the 5800h. If the Legion can be successfully hacked then the Zephyrs G14 with the RX 6800s (Navi 23) is possible likely
@zxc2689963 Can you boot the system and open MacIASL and go to File -> New from ACPI and select CPUSSDT and send a screenshot please.
Please try with this. It's just a theory
Disable the EC SSDT and try again.
zxc2689963
This is the EFI I booted to Monterey, which can only be used for booting the system, not for installation, and requires configuration modifications to install: Genericusbxhci. kext cancelled, cpus=1 cancelled, voodootscsyncamd-16cores.kext selected. This can be used to install BigSur
  • EFI-Monterey.zip
Why 16 cores? It’s a 8 core CPU. If that works though try using the 16 core cpu patch rather than 8.
alexjaixd
May I join in for discussions and possibly further development? Since we're now kinda stuck on driving all 8 cores under Monterey. But under Big Sur, all 8 cores are recognised. Why not now focus on trying Jo-Toku's suggestion to drive 6600M under Big Sur or Catalina and see if this works?
"So I made two discoveries recently with regards to hardware acceleration. Not sure if some of you know but what I found that's interesting is both AMD and Intel kexts in macOS /S/L/E I found share the same IOMatchCategory values under the kexts which is IOAcceleration. Unique to Intel is the IntelAccelerator IOClass which can be found in the AppleIntelSKLGraphics and AppleIntelICLGraphics kexts. I am quite sure with the info we've found so far it is possible to create a SSDT or even kext driver of sorts. We just need to figure out how to designate the AMD Vega properly as an internal IGPU.
Secondly (on a fairly related note of injecting AMD codes for acceleration), I managed to recently successfully boot up a RX6600 card in a Z590 system under Catalina. As we know the RX6600 isn't supported until Monterey, but I managed to fill in the required gaps in the Apple AMD kexts (AMDRadeonX6000Controller and AMDFramebuffer) by adding a Navi 23 class and the RX6600 device-id. I was totally amazed it booted up. This means it is totally possible to add the Vega 8 for acceleration.
Damn, If the below can work, would be Awesome!
"Alright, that's good going - it might work for my Atari VCS. And thanks for the explanation about the IOAcceleration.
With regards to the RX6600 Catalina solution, well this is what I did:
  1. Made an external USB SSD install of Catalina. Disabled SIP from Recovery mode and Gatekeeper for both Monterey and Catalina (from separate installs).
  2. Made a copy of the following Catalina kext files onto Catalina Desktop, plus from Monterey Beta in separate folder:
    AMDRadeonX6000.kext
    AMDRadeonX6000Framebuffer.kext
    AMDRadeonX6000HWServices.kext
  3. Reading the equivalent Monterey files, edited the Info.plist of Catalina kext files by transferring over missing sections of the AMD Info.plist (cutting and pasting) in the kexts, with particular regards to the Navi23 IOKitPersonality details and then added the FF731002 device-id to the end of it under IOPCIMatch. Saved the edited Info.plists.
  4. Copied the files over into S/L/E, renabled Gatekeeper and SIP and then rebooted with RX6600."
Wait...Could this also work on the Legion 5 maybe? The Desktop RX 6600 is the same card as the 6600m.🤔🧐
alexjaixd
It's a good idea if you can drive RX6600m in BigSur. Can you provide KEXT of Monterey RX6600? I can't extract it without Monterey, so I want to try your method. I have saved ioreg in BigSur system. Recently, I am dealing with the problem that BigSur needs to restart several times to successfully enter the system, so I can only start in thin configuration.
These are the 3 Radeon X6000 kexts under Monterey S/L/E
  • Monterey-Radeon X6000 kexts.zip
