Huh??Where does one find these kernel patches?
Just take another look at the post you quoted from.Huh??Where does one find these kernel patches?
Just take another look at the post you quoted from.So just copy, paste into the config.plist?Huh??Just take another look at the post you quoted from.
alloc_dma_buffer(this,*(IOMapper **)(this + 0x130),(ulong)*local_50 << 4 | 8,0x200,3,'@',(IOBufferMemoryDescriptor **)pplVar18,(IODMACommand **)pplVar2);alloc_dma_buffer(this,*(IOMapper **)(this + 0x130),(ulong)*local_50 << 4 | 8,0x200,0x13,'@',(IOBufferMemoryDescriptor **)pplVar18,(IODMACommand **)pplVar2);plVar12 = (long *)IOBufferMemoryDescriptor::withOptions(1,(ulong)(*puVar16 << 0xb),0x1000);plVar12 = (long *)IOBufferMemoryDescriptor::withOptions(0x11,(ulong)(*puVar16 << 0xb),0x1000);For you does it work?If the patches cannot be further trimmed, should them get PR-ed to be merged into the ForceAquantiaEthernet kernel quirk in OC?
I don't have any Aquantia card, so I can't test.For you does it work?
I’ll create a Patch Theory post today. Meanwhile, your analysis of the patches is correct.So after studying the patches, I've concluded that this is what they do:
Patch 1: Changes 3 (0x3) to 0x13 in this code snippet from the disassembled code.
Is changed to:
Patch 2: Changes 0x1 to 0x11
Is changed to:
Patch 3 and 4 are basically the same but change bytes in another function.
I wonder how exactly that increasing the byte by 0x10 would fix this, but unfortunately it's hard to figure out what the function alloc_dma_buffer actually does with only the disassembled code.
If the patches cannot be further trimmed, should them get PR-ed to be merged into the ForceAquantiaEthernet kernel quirk in OC? Here is the where the Aquantia patch is in the code.
OpenCorePkg/Library/OcAppleKernelLib/CommonPatches.c at master · acidanthera/OpenCorePkg
OpenCore bootloader. Contribute to acidanthera/OpenCorePkg development by creating an account on GitHub.github.com
I tried it with my GC-AQC113C, which has (spoofed) device ID 0x94C0. Some suggestions:@CaseySJ I am double checking if I have put all as you said
I have this:
have you the same device id as mine?
I would try to have a more solid and successful database (Device id and platform) before to submit a PRI don't have any Aquantia card, so I can't test.
This happened to me in Ventura once, but I made the port Inactive and then Active. I also did a cold boot.Tested, same behaviour
after few minutes it says connected but wrong ip and subnet mask and so on
Tested also @ different hardware speed different from 10Gbit
Interesting…Tested also in Monterey 12.6.1
It is the same
Maybe not useful to test on trx40 and I hope other people could give a positive feedback
log show --last boot | grep Aquantia > bootlog.txt
No, in both OS I useDoes the TRX40 system crash when cable is connected?
Is this everything related to Aquantia from the system log? There are too few logs in this file. There should be thousands of log entries related to Aquantia.@CaseySJ
I have few lines in bootlog
Also please post a screenshot of those 4 patches. I know you don’t like Clover Configurator, but it shows these patches very clearly. Because I am sitting by the fireplace with just my iPad, I cannot open a plist editor. I actually avoid plist editors as much as possible (just my preference, don’t mean to upset anyone).I have posted the entire file I have had
now trying with additional boot arg ( I did not use it)
not trueI know you don’t like Clover Configurator
