for (size_t i = 0; i < AppleSMCBufferTotal; i++) {
// IOMapper::gSystem is both an AppleVTD instance and an event bitset waiting until it arrives (great idea)
// XNU decides whether IOMapper will arrive based on kHasMapper (0x2) bit in IOMapper::gSystem.
// This bit is directly not set when dart=0/-x boot-args are passed when SIP FS protection is off.
// Otherwise, when IOMMU is unavailable (detected by missing DMAR table), it is IOPCIFamily job
// to unset the bit in a call to IOPCIPlatformInitialize -> AppleVTD::install.
// In 10.12 and earlier this is done in IOPCIBridge::configOp.
// In 10.13 and newer this is done in AppleACPIPlatformExpert::start -> ::initPCIExpressSupport (does it still race :).
// IOBufferMemoryDescriptor::inTaskWithOptions calls to IOMapper::checkForSystemMapper unless kIOMemoryMapperNone
// is provided, which forwards the call to waitForSystemMapper if kHasMapper bit is set.
// One may guess that IOPCIBridge::configOp is called later, and that this whole code results in an infinite
// loop in IOMapper::waitForSystemMapper() if VTD is unavailable on macOS prior 10.13.
// A friendly fix would have been removing kHasMapper from IOMapper::gSystem, which is safe, since
// the class instance is 8-byte aligned, yet that would result in issues on real Macs.
// reinterpret_cast<uintptr_t &>(IOMapper::gSystem) &= ~static_cast<uintptr_t>(kWaitMask);
// So we pass kIOMemoryMapperNone, which seems to be natural under these conditions.
memoryDescriptors[i] = IOBufferMemoryDescriptor::inTaskWithOptions(kernel_task, kIOMemoryMapperNone, allocSizes[i], windowAligns[i]);
if (memoryDescriptors[i]) {
auto r = memoryDescriptors[i]->prepare();
if (r == kIOReturnSuccess) {
memoryMaps[i] = memoryDescriptors[i]->map();
if (memoryMaps[i]) {
bzero(reinterpret_cast<void *>(memoryMaps[i]->getVirtualAddress()), allocSizes[i]);
DBGLOG("prov", "descriptor %lu was mapped", i);
} else {
PANIC("prov", "descriptor %lu map failure", i);
} else {
PANIC("prov", "descriptor %lu prepare failure %X", i, r);
} else {
PANIC("prov", "descriptor %lu alloc failure", i);
LAB_00001ddc:
_kprintf(pcVar11,"start");
else {
(**(code **)(*plVar6 + 0x20))(plVar6);
uVar7 = IOMapper::copyMapperForDevice(*(IOService **)(this + 0x130));
*(undefined8 *)(this + 0x138) = uVar7;
IOEthernetController::setAVBPacketMapper((IOMapper *)this);
iVar5 = setup_slave_io(this);
if (iVar5 == 0) {
uVar10 = *arg_ptr;
if ((uVar10 & 2) != 0) {
_IOLog("%s - AXGE version check fail\n","start");
uVar10 = *arg_ptr;
if ((uVar10 & 1) != 0) {
pcVar11 = "%s - AXGE version check fail\n";
goto LAB_00001ddc;
LAB_000020fa:
else {
uVar7 = IOMapper::copyMapperForDevice(*(IOService **)(this + 0x128));
*(undefined8 *)(this + 0x130) = uVar7;
iVar4 = setup_slave_io(this);
if (iVar4 == 0) {
uVar10 = *arg_ptr;
uVar10 = *arg_ptr;
goto LAB_000020fa;
Disabling VT-d
When debugging PCIe device drivers, it is often useful to temporarily disable VT-d so that I/O addresses are the same as the corresponding physical addresses. To disable VT-d, add the following to your kernel boot args:
If the problem you are debugging goes away in this mode, it usually indicates one of the following mistakes:
dart=0x0
- Some part of your code is incorrectly passing a physical address in RAM to your device for DMA purposes instead of an I/O address.
- Your code failed to call prepare or called prepare incorrectly on an IOMemoryDescriptor object before using it to perform DMA.
I doubt the boot arg would actually do anything if it just disables VT-d which is already unavailable, but I guess you could try.What I also found is this? - Disable AppleVTD - Boot Arg
Debugging Thunderbolt Drivers
Explains an external expansion interface for improving transfer speed between devices.developer.apple.com
Which states:
Is there anyone who could try this I cannot try for the next week on my hackintosh because I am on vacation.I doubt the boot arg would actually do anything if it just disables VT-d which is already unavailable, but I guess you could try.
M1 and later Apple Silicon machines use Apple-designed (or Apple-customized?) PHY hardware called “Apple Type-C PHY” (ATCPHY) that supports USB3, DisplayPort, and TB3/USB4 modes. This piece of hardware is in charge of turning the USB3/DP/TB protocol data into signals on the wires. Since we’re dealing with very high-speed signals (up to 20Gbps per pair), the PHY has to be very complex and there are a lot of analog knobs that need to be individually calibrated. With USB2, you can get away with having universal settings that work for every device, but that won’t work for USB3 and other higher-speed protocols!
The job of the PHY driver is to configure the physical hardware with settings specific to your particular chip, which are calibrated at the factory, and to manage reconfiguration of the entire PHY hardware as different modes are switched in and out. In practice, this means a huge number of “magic” register pokes, including some with variable data that comes from factory-written eFuses.
Tried and this tweak is a no-go. At least it didn't cause any KPs but the network connection got only as far up to Self Assigned IP.What I also found is this? - Disable AppleVTD - Boot Arg
Which states:
Do you have DisableIoMapper => disabled in OC config.plistTried and this tweak is a no-go. At least it didn't cause any KPs but the network connection got only as far up to Self Assigned IP.
Yes DisableIoMapper is set as FalseDo you have DisableIoMapper => disabled in OC config.plist
Without source code it’s more difficult to pinpoint the issue, but the disassembled C code posted by @ExtremeXT is helping considerably. I’ve found at least two differences in the debug logs from the same card on AMD and on Intel.@CaseySJ Do you have an update on a possibility of patching yet?
What in the kext's code should we actually be looking for? Where it says to use appleVTD?
Can you send where in the code that happens?but I have isolated the code where the loop occurs.
I can, but it won’t help. The cause is much deeper hidden.Can you send where in the code that happens?
At this point, do you think it could still succeed in making a patch? this is not to be negativeI can, but it won’t help. The cause is much deeper hidden.
That’s a fair question, not negative but reasonable. I think it’s still too early. I’ll collect more logs, and turn on AppleVTD logs as well. We do have the source code for AppleVTD, which is part of IOPCIFamily.At this point, do you think it could still succeed in making a patch? this is not to be negative
2022-11-27 10:35:49.601408-0800 configd: [com.apple.SystemConfiguration:QoSMarking] QoS marking policy: en1: enable (default)
2022-11-27 10:35:49.653981-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: start
2022-11-27 10:35:49.654128-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1 link INACTIVE
2022-11-27 10:35:49.758002-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1: link inactive timer fired
2022-11-27 10:35:49.758047-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: status = 'media inactive'
2022-11-27 10:35:49.758105-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INACTIVE
2022-11-27 10:35:49.758107-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: Inactive
2022-11-27 10:35:49.758127-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: Inactive
2022-11-27 10:35:49.758147-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] AUTOMATIC-V6 en1: status = 'media inactive'
CABLE CONNECTED:
2022-11-27 10:36:54.436575-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1 link ACTIVE
2022-11-27 10:36:54.436668-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT
2022-11-27 10:36:54.436876-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 0 for 1.951757
2022-11-27 10:36:54.436928-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: link-local address is ready, starting
2022-11-27 10:36:54.436928-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: Solicit
2022-11-27 10:36:54.436963-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: sending Router Solicitation (1 of 3)
2022-11-27 10:36:56.390407-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 2 for 2.794896
2022-11-27 10:36:59.185408-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 5 for 4.789545
2022-11-27 10:36:59.353603-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: sending Router Solicitation (2 of 3)
2022-11-27 10:36:59.358641-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: Acquired
2022-11-27 10:36:59.358682-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCPv6ClientStart(en1): use permanent address
2022-11-27 10:36:59.359029-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] AUTOMATIC-V6 en1: publish success { IPv6, DNS } [PLATDiscovery]
2022-11-27 10:36:59.359030-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1: DHCPv6 client still active
2022-11-27 10:36:59.360586-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] AUTOMATIC-V6 en1: publish success { IPv6, DNS } [PLATDiscovery]
2022-11-27 10:36:59.360588-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1: DHCPv6 client still active
2022-11-27 10:36:59.363651-0800 configd: [com.apple.SystemConfiguration:IPMonitor] network changed: v4(en2:192.168.1.115) v6(en1+:—REDACTED—, en2) DNS! Proxy! SMB
2022-11-27 10:36:59.387422-0800 configd: [com.apple.SystemConfiguration:IPMonitor] Publishing data to agent DNSAgent-@en1 (102 bytes)
2022-11-27 10:36:59.926686-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: all autoconf addresses detached/deprecated
2022-11-27 10:36:59.926812-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] AUTOMATIC-V6 en1: publish success { IPv6, DNS } [PLATDiscovery]
2022-11-27 10:36:59.926813-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1: DHCPv6 client still active
2022-11-27 10:36:59.973915-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: all autoconf addresses detached/deprecated
2022-11-27 10:36:59.974135-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] AUTOMATIC-V6 en1: publish success { IPv6, DNS, DHCPv6 } [PLATDiscovery]
2022-11-27 10:36:59.975754-0800 configd: [com.apple.SystemConfiguration:IPMonitor] network changed: v4(en2:192.168.1.115) v6(en1:—REDACTED—, en2) DNS! Proxy SMB
2022-11-27 10:37:00.004092-0800 configd: [com.apple.SystemConfiguration:IPMonitor] Publishing data to agent DNSAgent-@en1 (145 bytes)
2022-11-27 10:37:00.029763-0800 configd: [com.apple.SystemConfiguration:IPMonitor] en1: nat64 prefix unavailable
2022-11-27 10:37:00.029780-0800 configd: [com.apple.SystemConfiguration:IPMonitor] en1: nat64 prefixes updated
2022-11-27 10:37:00.029997-0800 configd: [com.apple.SystemConfiguration:IPMonitor] en1: PLAT discovery complete {
2022-11-27 10:37:00.359079-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: all autoconf addresses detached/deprecated
2022-11-27 10:37:00.359399-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] AUTOMATIC-V6 en1: publish success { IPv6, DNS, DHCPv6 } [PLATDiscovery]
2022-11-27 10:37:03.211079-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT gathering began at 9
2022-11-27 10:37:04.211150-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: SELECT
2022-11-27 10:37:04.211323-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: SELECT waiting at 10 for 1.000000
2022-11-27 10:37:04.216097-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: BOUND
# IP address received and assigned:
2022-11-27 10:37:05.824266-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: setting 192.168.1.75 netmask 255.255.255.0 broadcast 192.168.1.255
2022-11-27 10:37:05.834106-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] dhcp_bound(en1) 192.168.1.75
2022-11-27 10:37:05.844900-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: publish success { IPv4, DNS, DHCP }
2022-11-27 10:37:05.847625-0800 configd: [com.apple.SystemConfiguration:IPMonitor] network changed: v4(en1+:192.168.1.75, en2) v6(en1:—REDACTED—, en2) DNS! Proxy SMB
2022-11-27 10:37:05.862762-0800 configd: [com.apple.SystemConfiguration:IPMonitor] Publishing data to agent DNSAgent-@en1 (159 bytes)
2022-11-27 10:37:07.448430-0800 configd: (IPConfiguration) [com.apple.IPConfiguration:Server] LINKLOCAL en1: status = 'success'
2022-11-27 09:59:59.658970-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: start
2022-11-27 09:59:59.659216-0800 0x36d configd: [com.apple.SystemConfiguration:QoSMarking] QoS marking policy: en1: enable (default)
2022-11-27 09:59:59.659421-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1 link INACTIVE
2022-11-27 09:59:59.762880-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1: link inactive timer fired
2022-11-27 09:59:59.762923-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: status = 'media inactive'
2022-11-27 09:59:59.762986-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INACTIVE
2022-11-27 09:59:59.762988-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: Inactive
2022-11-27 09:59:59.763007-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: Inactive
2022-11-27 09:59:59.763027-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] AUTOMATIC-V6 en1: status = 'media inactive'
CABLE CONNECTED:
2022-11-27 10:01:15.716515-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] en1 link ACTIVE
2022-11-27 10:01:15.757407-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT
2022-11-27 10:01:15.757685-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 0 for 1.983972
2022-11-27 10:01:15.757715-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: link-local address is ready, starting
2022-11-27 10:01:15.757715-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: Solicit
2022-11-27 10:01:15.757738-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: sending Router Solicitation (1 of 3)
2022-11-27 10:01:17.743080-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 2 for 2.128184
2022-11-27 10:01:19.872462-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 4 for 4.320026
2022-11-27 10:01:20.523625-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: sending Router Solicitation (2 of 3)
2022-11-27 10:01:24.193219-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: ARP router: No leases to query for
2022-11-27 10:01:24.193371-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 9 for 8.150812
2022-11-27 10:01:24.999514-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] RTADV en1: sending Router Solicitation (3 of 3)
2022-11-27 10:01:32.344252-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: ARP router: No leases to query for
2022-11-27 10:01:32.344367-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 17 for 8.328620
# Here a self-assigned IP is applied:
2022-11-27 10:01:33.948508-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] LINKLOCAL en1: setting 169.254.147.64 netmask 255.255.0.0 broadcast 169.254.255.255
2022-11-27 10:01:33.958734-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] LINKLOCAL en1: publish success { IPv4 }
2022-11-27 10:01:40.675818-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: ARP router: No leases to query for
2022-11-27 10:01:40.675942-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 25 for 8.347753
2022-11-27 10:01:49.023821-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: ARP router: No leases to query for
2022-11-27 10:01:49.023912-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: reported address acquisition failure symptom
2022-11-27 10:01:49.024084-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 34 for 8.237974
2022-11-27 10:01:57.262803-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: ARP router: No leases to query for
2022-11-27 10:01:57.262928-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 42 for 8.991415
2022-11-27 10:02:06.256376-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: ARP router: No leases to query for
2022-11-27 10:02:06.256543-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 51 for 8.191725
2022-11-27 10:02:14.449982-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: ARP router: No leases to query for
2022-11-27 10:02:14.450143-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: INIT waiting at 59 for 8.852795
2022-11-27 10:02:23.306220-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: ARP router: No leases to query for
2022-11-27 10:02:23.306485-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] LINKLOCAL en1: publish success { IPv4 }
2022-11-27 10:02:23.306486-0800 0x36d configd: (IPConfiguration) [com.apple.IPConfiguration:Server] DHCP en1: status = 'no server'
# alloc_rx_rings just finished as we can see by the "exit" sign <==
2022-11-27 09:59:59.584078-0800 kernel: (AppleEthernetAquantiaAqtion) <== AppleEthernetAquantiaAqtion::alloc_rx_rings:0x00000001
# setup_intr function now begins as we can see by the 'entry' sign ==>
2022-11-27 09:59:59.584079-0800 kernel: (AppleEthernetAquantiaAqtion) ==> AppleEthernetAquantiaAqtion::setup_intr
2022-11-27 09:59:59.584170-0800 kernel: (IOPCIFamily) setTunnelL1Enable(0x100000281) 2->0
2022-11-27 09:59:59.584172-0800 kernel: (IOPCIFamily) setTunnelL1Enable(0x100000281) 2->0
2022-11-27 09:59:59.584176-0800 kernel: (IOPCIFamily) setTunnelL1Enable(0x100000281) 2->0
2022-11-27 09:59:59.584177-0800 kernel: (IOPCIFamily) setTunnelL1Enable(0x100000281) 2->0
2022-11-27 09:59:59.584191-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - MSI Interrupt found. Line = 0x00000000, type = 0x00010000
2022-11-27 09:59:59.584212-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - MSI Interrupt found. Line = 0x00000001, type = 0x00010000
2022-11-27 09:59:59.584218-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - MSI Interrupt found. Line = 0x00000002, type = 0x00010000
2022-11-27 09:59:59.584223-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - MSI Interrupt found. Line = 0x00000003, type = 0x00010000
2022-11-27 09:59:59.584229-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - MSI Interrupt found. Line = 0x00000004, type = 0x00010000
2022-11-27 09:59:59.584234-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - MSI Interrupt found. Line = 0x00000005, type = 0x00010000
2022-11-27 09:59:59.584240-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - MSI Interrupt found. Line = 0x00000006, type = 0x00010000
2022-11-27 09:59:59.584249-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - Interrupt source registered
2022-11-27 09:59:59.584250-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - Interrupt source registered
2022-11-27 09:59:59.584251-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - Interrupt source registered
2022-11-27 09:59:59.584252-0800 kernel: (AppleEthernetAquantiaAqtion) setup_intr - Interrupt source registered
# success
2022-11-27 09:59:59.584252-0800 kernel: (AppleEthernetAquantiaAqtion) <== AppleEthernetAquantiaAqtion::setup_intr status = 0x00000001
# now the next step starts, which is initializing the hardware
2022-11-27 09:59:59.584253-0800 kernel: (AppleEthernetAquantiaAqtion) ==> AppleEthernetAquantiaAqtion::init_enet_hw
2022-11-27 10:35:49.589065-0800 0x1a4 kernel: (AppleEthernetAquantiaAqtion) <== AppleEthernetAquantiaAqtion::alloc_rx_rings:0x00000001
2022-11-27 10:35:49.589066-0800 0x1a4 kernel: (AppleEthernetAquantiaAqtion) ==> AppleEthernetAquantiaAqtion::setup_intr
2022-11-27 10:35:49.589068-0800 0x1a4 kernel: (AppleEthernetAquantiaAqtion) setup_intr - MSI Interrupt found. Line = 0x00000001, type = 0x00010000
2022-11-27 10:35:49.589152-0800 0x1a4 kernel: (AppleEthernetAquantiaAqtion) setup_intr - Interrupt source registered
# success
2022-11-27 10:35:49.589153-0800 0x1a4 kernel: (AppleEthernetAquantiaAqtion) <== AppleEthernetAquantiaAqtion::setup_intr status = 0x00000001
2022-11-27 10:35:49.589154-0800 0x1a4 kernel: (AppleEthernetAquantiaAqtion) ==> AppleEthernetAquantiaAqtion::init_enet_hw
