@PoMpIs Can you try this DEBUG EFI? Boot macOS and when it gets stuck again take a screenshot, boot back to another OS and zip the log file + the SysReport file at the root of the EFI partition.
- ExtremeXT
Result of this EFI:
- ExtremeXT
Prohibited sign is good news, as it means that we passed the error. Did it have text on the left of it? Can you try the latest EFI I sent too?With this EFI in the first attempt this came out on the screen:
and a few seconds later this:
and then back to the OpenCore selection screen
On the second try it showed this:
that was in Ventura....
and in Monterey this comes out:
Please leave it running until macOS loads, it's slow because it's writing things to the log.
- ExtremeXT
Okay, I know how to fix non monotonic time, I'll send a new EFI in a bit.If I have tried it right now... I am attaching some screenshots from my mobile, one second
Monterey:
in ventura it restarts in 3 seconds, this is what i had time to capture:
Sysreport has not generate with last EFI
... my fault, sorry@Middleman
The only thing -no_compat_check does is bypass the SMBIOS check, as they're using MacPro7,1, it won't do anything.
@PoMpIs
Please try this one.
- ExtremeXT
Can you make an USB map? Send the UTBMap file here.
Yes of course, it's what I use for my other hacksCan you make an USB map? Send the UTBMap file here.
GitHub - USBToolBox/tool: the USBToolBox tool
the USBToolBox tool. Contribute to USBToolBox/tool development by creating an account on GitHub.github.com
- ExtremeXT
@PoMpIs
Your log file is still not complete, you have to boot macOS too, wait until it gets stuck with the DEBUG EFI.
Your map is fine as you're under the 15 ports limit. You shouldn't remove any unless you are above 15 ports per controller.
- ExtremeXT
OK, try this one.The EFI that generates the LOG does not go beyond there, at the end it returns to the OpenCore selection screen, it does nothing else
i will try again, It is fun![]()
OK, try this one.
