Ah ok so thats no big deal then.alright! will do, Ive tested a few things, I haven't gotten to usb map yet, however it appears putting the bluetooth firmware as higher priority on open core makes it work
after a few restarts that work around seems to only work sometimes. not 100% sure how often but less than 50%Ah ok so thats no big deal then.![]()
If itโs not perfect then for sure report it.after a few restarts that work around seems to only work sometimes. not 100% sure how often but less than 50%
Try going into your config.plist and changing your processor type to 1537 Save and restart.Can't seem to get it to work with my 3600 though.
if (Cpu->ThreadCount >= 8) {
Cpu->AppleProcessorType = AppleProcessorTypeXeonW;
} else {
Cpu->AppleProcessorType = AppleProcessorTypeCorei5Type5;
Iโve got the latest 1.0.2 and I see unknown on my ryzen 5 3500. What do I need to put in cpu type? 1537?
It's within the PlatformInfo > Generic section of your config.
1537 is the correct value to change it too for a 6 core CPUYeah I know where to put it I was just confirming what to put in there for my cpu to display properly. Thanks.
hi everybody. it is only possible on Bigsur 11,4, beta ?
I don't see where i made a mistake
i am on an external SSD with bigsur 11.3.1
