Fix CPU Name with RestrictEvents
AudioGod
alright! will do, Ive tested a few things, I haven't gotten to usb map yet, however it appears putting the bluetooth firmware as higher priority on open core makes it work
Ah ok so thats no big deal then. đź‘Ť
AudioGod
after a few restarts that work around seems to only work sometimes. not 100% sure how often but less than 50%
If it’s not perfect then for sure report it.
Theres a link to the Bug report a few posts up.
Moozuki
Can't seem to get it to work with my 3600 though.
AudioGod
Try going into your config.plist and changing your processor type to 1537 Save and restart.
That should get it to kick in
Moozuki
Well, at least its not showing unknown anymore...
AudioGod
@Shaneee if he is then would that mean 1537 relates to the 5600X only? (No it can’t be thinking about it, must be an older version of the kext)
I don't think so. OpenCore sets two CPU types for AMD by default, Xeon W for 8 cores or more and the i5 for less. Without seeing the Lilu debug to see what the kext is trying to replace can't say for sure it would be the same CPU type to replace.
C++:
  if (Cpu->ThreadCount >= 8) {
    Cpu->AppleProcessorType = AppleProcessorTypeXeonW;
  } else {
    Cpu->AppleProcessorType = AppleProcessorTypeCorei5Type5;
Moozuki
WHOOHOO!
I forgot to update kext even after I downloaded it 🥴
baronerosso
It works here too with last 1.0.2 build
savage001
I’ve got the latest 1.0.2 and I see unknown on my ryzen 5 3500. What do I need to put in cpu type? 1537?
It's within the PlatformInfo > Generic section of your config.
savage001
Yeah I know where to put it I was just confirming what to put in there for my cpu to display properly. Thanks.
AudioGod
1537 is the correct value to change it too for a 6 core CPU đź‘Ť
savage001
Ahh much better
AMDPUSH
hi everybody. it is only possible on Bigsur 11,4, beta ?
AMDPUSH
I don't see where i made a mistake
i am on an external SSD with bigsur 11.3.1
savage001
Where is that folder located? You only need the .kext inside your kext folder in your EFI directory and make sure it’s added to your config.plist.
