macOS Sequoia
All good here on macOS Sequoia Beta 3 and the latest NootedRed kext. Using BetterDisplay for the scaled 2K resolution, which is actually quite clear if you're long sighted like me.
I decided to jump in as well.
  • Applied latest beta AMD-OSX kernel patches from here
  • Applied latest pre-release Acidanthera kexts from here
  • Applied latest AMDRyzenCPUPowerManagement kexts from here
  • Did not need to use -lilubetaall because latest (pre-release) Acidanthera kexts support Sequoia (thanks to @Lorys89)
Sequoia is installed on my Asus X670E Gene.
Intel WiFi not working yet. Will need to wait for Sequoia version of AirportItlwm. If you're unable to install updates from App Store, it may be because Ethernet port en0 has been zombified by the non-working WiFi driver. To remedy, simply type this in Terminal and reboot:
Bash:
cd /Library/Preferences/SystemConfiguration
sudo rm NetworkPreferences.plist
Screenshot 2024-07-13 at 10.22.22 AM.pngScreenshot 2024-07-13 at 12.07.31 PM.png
@CaseySJ awesomeness!. My Wi-Fi solution involves a 50ft Ethernet cable and a Netgear 3700XT wi-fi extender/access point. I can’t trick it into making iPhone mirroring work, but I have received texts and a phone call.
  • Haha
Reactions: Deleted member 4886
Heliport and itlwm work, as reported by @Lorys89 here, but the developer himself apparently has very little time to work on this.
I have ordered a Broadcom WiFi 6 module from AliExpress, but I don't know if it will work. It's cheap enough to experiment with, and because I have an OrangePi 5 Plus computer, I can always install it into that.
I’d be very interested in hearing your thoughts when it arrives. In Sequoia Beta 1 @Shaneee had a fix for Intel BT, but then it stopped again in Beta 2. I do have sound in all 3 betas using AppleACLU.kext 1.9.1, but only in the GenMachine with the 5700U, but not with the 4700G.
Reactions: CaseySJ
It's possible that some symbols changed for the BT kexts which stopped them working. Currently looking into AirportItlwm just now though.
Sequoia Public Beta is available!, updated the 5700U and 4700G last night.Screenshot 2024-07-16 at 12.28.28 AM.pngScreenshot 2024-07-16 at 8.26.59 AM.png
@CaseySJ That Orange Pi Broadcom WiFi 6 card you linked looks to have a custom interface, I.e. not a standard M.2 E or A connector/interface. The Pins along the bottom seem to be reversed, with the short section on the lefthand side. Normally with an E &/or A M.2 card the short section of pins is on the righthand side.
Screenshot 2024-07-16 at 20.27.29.png Broadcom BCM4375 short section of pins on left.
Screenshot 2024-07-16 at 20.28.06.png Realtek WiFi/BT card for Orange Pi 5 Plus, short sections of pins on right.
I think that is why they state it won't work in the Orange Pi 5 Plus. All the WiFi/BT cards I have seen that are recommended for the Pi 5 Plus have standard M.2 E & A connectors.
Are you aware of a PCIe adapter that will work with this non standard Broadcom card?
View attachment 14578 Broadcom BCM4375 short section of pins on left.
View attachment 14579 Realtek WiFi/BT card for Orange Pi 5 Plus, short sections of pins on right.
@Edhawk,
You're quite right; the Orange Pi Wi-Fi 6 card is Key M that is meant for standard M.2 PCIe slots. Typical Wi-Fi models are either Key E or Key A/E.
Key M provides access to 4 PCIe lanes, but Keys A and E provides access to 2 lanes of PCIe, plus UART and USB buses for Bluetooth.
The Orange Pi card may be specific to the Orange Pi because it is not even recognized when installed into a PC motherboard.
Dumb question perhaps but are the beta patches backwards compatible with Sonoma? So in other words, could I future proof it for when Sequoia officially releases? Or best to wait until all quirks are ironed out (typing this out I think... yes :D )
Yes beta patches still work on all previously supported versions :)
Reactions: RyzeCooker
The Beta Patches worked fine in macOS Sonoma for me.
Good to hear. Gonna prep my system then (y)
I successfully installed Sequoia to to my Asus TUF X670E and Ryzen 7959X3D. However when I mount the EFI partitions to copy the EFI folder from the USB to the SSD, the mount efi window in Opencore configuration shows the mounted, but the don’t show up in the finder window. I’ve tried mounting them in terminal and using the mountefi application with the same result. They all report the partitions mounted but they don’t show up in finder so I can’t copy the efi folder. Any ideas?
Apparently this is a problem with the latest build of MacOS 15 (build 24A5309e). No matter what method I use to mount the EFI partitions, they won't show up in finder. Two different machines have done this. Build 24A5298h did not do this. It happens on machines with Intel or AMD CPUs. I hope someone smarter than me can figure it out!
I also tried disabling SIP. No change, still can’t see the EFI folders in finder.
The other thing to remember with the patches, as a general comment, is to make sure you update your CPU core numbers to the 'algrey - Force cpuid_cores_per_package' patches, as per: https://dortania.github.io/OpenCore-Install-Guide/AMD/zen.html#kernel
That's caught me out a couple of times when updating the patch list :) (EDIT: and, unbelievably having posted that, again this morning when installing Sequoia!!).
EDIT: Huh - interesting. The script MountEFI-update doesn't work in 15 due to Apple changing to FSKit to handle FAT32 partitions (https://github.com/corpnewt/MountEFI/issues/28). Fortunately, you can get that functionality back through Mount-MS-DOSPartition (https://github.com/chris1111/Mount-MS-DOS-Partition).
I have disabled SIP on my Sequoia beta 5 machine and tried this. It is definitely not mounting the EFI partition. Is there something else I need to do to make this work?
Hello everyone, could someone take pity on me and look at my EFI, there is a problem somewhere. I can't install Seqouia
Nothing attached, there was a file included with your post but when I tried to download it I got the message the file didn't exist. Now there is no attachment, please reupload your EFI.
Reactions: ManuelB
I re-uploaded it
